Vizio Gallevia GV42LF 42 in. LCD Television Logo
Posted on Jan 01, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Vizio 42"LCD Red Dots when warm
I have a Vizio 42" LCD and after an hour or so, red dots/snow appear in places where there should be black or other dark colors. I've heard that decreasing the voltage on the tv will stop this, but I don't know how to do that. How do I decrease the voltage to stop the red dots? Is there another solution?
vince
Level 3:
  • Vizio Master 2,530 Answers
  • Posted on Jan 01, 2018
 vince
Vizio Master
Level 3:
Answers
2530
Questions
0
Helped
748803
Points
8845
Sometimes changing from hdmi to composite inputs solves it.
5 Related Answers
Anonymous
  • 98 Answers
  • Posted on Feb 06, 2009
SOURCE: Red Dots
Need to adjust some voltage on Power Board & Y-Main Board
Anonymous
  • Posted on Feb 07, 2009
SOURCE: red dots on my plasma screen tv
red dots means dead pixels if you can return it or sell it because it can sometimes spread out, but you can get it fixed for about 140 dollars at minium at a place that fixes the panels and that of tv's if you can tho return it ASAP
Anonymous
  • 56 Answers
  • Posted on Feb 16, 2009
SOURCE: RED DOTS VIZIO HDTV P50 10A
Decrease the Vs voltage on the power supply will fix the problem.
Anonymous
  • 65 Answers
  • Posted on Aug 01, 2009
SOURCE: Vizio 52 Red dots
It sounds like you have a defective LCD panel. This is more common with the plasma TVs. Are you sure it's an LCD?
Anonymous
  • 178 Answers
  • Posted on Oct 05, 2009
SOURCE: red dots like
If they are moving, it is a Random pixel discharge. This can be caused by 3 different problems, that are not easily diagnosed through a chat like this. 1. I could be a miss adjustment of critical voltages that control pixel discharge in the set, although i have not looked at your set in particular, some models are automatic and don't have an adjustment. 2. It could be the x board or equivalent, 3. It could be the panel it's self.
in my experience with this problem the adjustment rarely fixed the problem, more likely the Panel is failing, although sometimes the x board will cause this issue.
I am sorry I cannot get you any closer than that, I recommend getting a repair tech out to check it out. This set is repaired by replacing boards not component level, the boards can be expensive and I don’t want to recommend a board replacement unless I was the tech to actually see the problem.
Tv black with red green yellow dots but when warms up it alright
Try backstepping the set resolution on your TV to see if that cures it.
Please rate my help++++Thanks for using FIXYA
1helpful
2answers
Pixelation
The problem is more or less with the LCD screen itself. The manufatcurer covers dead or burnt pixels.I would suggest contact Vizio Support on the following number
Technical Support
Toll-Free: 877.698.4946
Thanks
proton
2helpful
Vizio 52 Red dots
1helpful
Red, blue and green dots appear on screen like snow
ask ur service provider and ask him to change ur revolution or ask him to change ur sreen
3helpful
3answers
Red dots on screen
just video only what cable uusing how syour dvd player older ?
Black dots on the screen
This is the digital equivalent to "snow" on a standard TV set. This unit should still be under warranty. I would file a service claim to document the problem. It may not warrant service at this time, but log the problem as an intermittant problem. That should cover you should the problem become solid after the standard warranty period has expired.
Dan
Screen black after big storm...
The set has sound and no picture.If you the SSB could be the issue but the tiny red dots on a black screen will need the panle replaced also. There is a way troble shooting can be done to determine if you will need the SSB or the SSB and the panel.
1helpful
5answers
Sansui Plasma, Green and Red Snow
I have the same tv - change the power supply. Corne Bronkhorst
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
