SOURCE: nOTIFICATIONS ON FACEBOOK DISAPPEARED, CANNOT
Go to: http://www.facebook.com/home.php#!/notifications.php when you are logged into facebook to view your notifications.
SOURCE: I'm an iPhone User. Whatsapp
Unless you are using an iPhone that supports multi-tasking (the iPhone 4) this is an unavoidable issue, unless you jailbreak and use an app like 'Backgrounder"
SOURCE: I'm an iPhone User. Whatsapp disconects as soon as
Manually pressing the sleep button tells the phone to stop all programs running. You'll need to let the phone fall asleep on its own.
SOURCE: I am having issues with my nexus s. I keep getting
I think you mean optimus S :). There are a couple of things I would try to do to fix this problem. first I would try to check and see if the browser cache is clear. Setting up you browser to dump the cache on exit is a good practice. If your Optimus is rooted you can also use one of the many applications on the market that can clean out your cache for both the internal and external memory automatically. If all else fails a clean wipe will always do the trick. The Optimus One has had some file system hiccups and this will almost certainly fix your problem. The google market place should install all of your lost apps. Hope this solves your problem. kidromulous
Testimonial: "he was very helpful and descriptive. his solution for wiping the phone cleared up the ptroblem. it also made the phone move faster as well. "
SOURCE: Whatsapp Nokia C6 ihave downlaod the last Whatsapp
First correct your date and time .. if it was correct restart the phone and its work .
if it not work re download the whatsapp .
It's a mobicel v2
