SOURCE: how to remove tail light housing from fender
The previous owner had left a socket on the tap under the fender!! There are two taps on the housing that hold the tail light to the fender. Taking these two off allows the taillight to be removed.
SOURCE: Remove right front fender on 2005 odyssey
NO 2 BOLTS ON TOP OF FENDER UNDER HOOD 1 BOLT BEHIND PLASTIC TRIM BY MIRROR PULL THIS PIECE BACK TOWARDS MIRROR OR IT WILL BREAK TABS OFF 1 BOLT UNDER ROCKER TRIM 1 SCREW INTO ROCKER AND 1 SCREW BEHIND PLASTIC SHROUD GOING INTO BUMPER FROM UNDER NEATH PULL BUMPER BACK SLIGHTY AND YOU WILL SEE A WHITE PLASTIC CLIP PULL BACK AND BEHIND THIS IS A BOLT REMOVE HEADLIGHT CLIP FROM FENDER AND LOSEN BOLT BY HINGE NOW FENDER SHOULD COME RIGHT OFF BOOK IS 2 HOURS TAKES 1 HOUR TO REMOVE BUT GOES ON IN ABOUT 30 NINUTES
SOURCE: 2008 honda odyssey side (driver) - 3rd row window glass shattered
i would be suprise if they warranty that unless some mechanical part was the culprit price wise from 350 and up .pierre
SOURCE: how do I remove the drivers front fender of a 1994 Dodge Ram 2500
yes undo your battery as ans air bag has a connector on the seat and if unplugged could cause air bags to go off with battery still hooked up leat sit for five min. should be four bolts or nuts holding seat down
SOURCE: Remove left front fender 1967 Chevelle
There are quite a few bolts on this fender. One on the bottom of the rocker, one between the the door and fender on the "A" pillar, one on the cal, one on the firewall then several on the inner fender and several on the radiator core support. after these are removes you need to take ou the head light assembly and you should have a fender brace under the front of the car. Hope this helps.
