SOURCE: Cascio
To sync the correct 12 hour with your day you need to set the date to the day before (if today is 21, then make sure the day window reads 20). Then spin the analog hands until the the date window turns to 21. At this point your watch is reading 12 AM (midnight). Then keep turning to set the correct time. If it is 9 am then stop the hands the first time you hit the 9 marker. If it is 9pm, then keep turning until the SECOND TIME your hour hand meets the 9 marker. This is now set for 9 pm.
That's how you do it. If you need more clarification let me know.
SOURCE: Hi, I have a Swatch Irony...I came from India, so
This is an analog watch.
Pull the set stem to the set position and advance 12 hours.
Hope this tip helps.
r/
David
SOURCE: the day and date does not change until just after
Advance the time 12 hours.
http://www.timex.com/info/Product_Instruction_Guides_Downloads
There are so many aplications use of the manual will be manditory.
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
http://antiqueclock.clockstop.com/
SOURCE: my calendar is switching 12 noon instead of
I would turn the watch hands 12 hours then you will be at the correct spot for the 12 Noon and 12 Midnight times.... At this point you may need to change the date again also
SOURCE: My timex watch changes the date at noon instead of
This is because you have reversed am with pm.
Set your watch 12 hours back and the problem should be solved.
You might want to wait till midnight or noon to check it's fine.
Note: if you see the day shows the previous day rather than the present day, you have to set the clock 24h ahead.
Problem solved!
