Question about Sanyo Televison & Video
My Sanyo Blu-Ray player keeps giving me a Cinavia Code 3 while playing a DVD (Store bought) How do I get rid of the code? Its a Sanyo TV as well, 50 inch, older model Plasma. Please help!
SOURCE:
SOURCE: My Sanyo DWM-400 plays some DVD's and won't play others.
I bought another DVD player. I found out that all DVD's don't play on all DVD brands of players. They are cheap enough these days so I decided it wasn't worth a repair bill. The Sanyo DWM-400 plays many of my store bought DVD's and not others. I never tried a home made DVD in it so I don't know how it responds.
Posted on Jun 26, 2008
dvinnedge
  • 35 Answers
SOURCE: Remote Control codes to control other brand devices
i have sony receiver codes 31759, 30158, 31758,
or 4 digit codes 0158 and 1758
Posted on Dec 04, 2008
Gurudristi
  • 98 Answers
SOURCE: How to connect BLU-RAY DVD player to Pioneer Plasma TV via HDMI
The best possible solution to your problem is :
Connect your blu ray player directly to the HDMI input of you Plasma and watch HD video....
and connect the 5.1/7.1 sound thru the optical or the coaxial link directly to your AVR 3805.
You will not loose anything on the Blu-Ray.
The sound is best processsed by the AVR3805, while the video, which is the real upgrade (BluRay) in terms of resolution of picture would be processed by your plasma.
Connect and Enjoy
Posted on Feb 27, 2009
SOURCE: LG Blu-Ray BD-370 unlock codes
http://www.multi-region.net/lg_5931
Posted on May 01, 2009
SOURCE: Universal Remote code for Insignia Blu-ray dvd player NS-2BRDVD
Insignia says it will not work with a universal remote there is no code.
Posted on Feb 02, 2010
My movie is muted while using my DVD player
How to Solve Cinavia Protection Issue During Blu-ray ...
www.ideerapp.com/solve-cinavia-protection-issue-during-blu-ray-playba...
If you meet Cinavia protection when playing a Blu-ray disc, you can read below to ...uses of some movies and other filmed entertainment in Blu-ray Disc players. ... Pause the video, wait 30 seconds for the audio to be un-muted, then skip over ...
How to Get Rid of Cinavia on Blu-ray Player
www.ideerapp.com/get-rid-of-cinavia.html
The content being played is protected by Cinavia™ and is not authorized for playbackon this device. ... When you play a movie with Cinavia, meidia players or devices will be detected to ... Pause the video, wait 30 seconds for the audio to be un-muted, then skip over ... It is a free player for DVD and general video formats.
Ultimate Cinavia Guide: the protection that refuses to be ...
Dec 21, 2015 | Televison & Video
What is a Cinavia code 3?
Hi Carol,
Why didn't you search "cinavia code 3"? I did and got a hit on the cinavia website which explained what the code meant.'
Aug 09, 2015 | Samsung Televison & Video
How can I play an Philips DVD disc on the blue- ray disc with the sound playing A box keep popping up on the tv telling me to www.cinavie. Com
The different codes are telling you, there is a copyright protection on the sound or the video. Sometimes parts are protected, because it was intended for other use.
See the link to:
Cinavia Messages Message Code 1
Nov 22, 2014 | Televison & Video
I get a message on my dvd player cinavia code 3
That means the disc your trying to watch is either pirated or corrupted
Nov 06, 2014 | Televison & Video
Cinavia message showed up in the middle of a dvd
Cinavia is a way to add a watermark on to Theater release and Blu-ray release movie soundtrack. The DVD player checks to see if the disc being played is authentic. The Cinavia message is from the DVD player and not the TV
Jun 27, 2014 | Samsung Televison & Video
I have 2 problems with my lg hb 966trw: a)
follow this steps and fix it. God bless you
No power
  1. Check if the power cord has been properly connected to the power outlet.
  2. Check if the main power has been switched on.
    (DVD player's power supply transformer could be burned out)
Screen is "frozen" or completely black, or Power button does not work
  1. Try turning the power off and wait 3 seconds before turning it on again.
  2. Make sure the TV and VCR (if connected) are set to the correct channel or line.
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
No sound
  1. Check if the TV and Amplifier (if connected) is turned on and set correctly.
  2. Check if the TV, DVD player and Amplifier are connected properly.
  3. Make sure the TV, DVD player and Amplifier volume are not set to Mute.
  4. There will be no sound output during Reverse Play / Pause / Step / Slow / Search.
  5. If the DTS soundtrack is enabled in the DVD Disc Menu, but you are using Stereo Analog audio, the sound will not work. Try switching the soundtrack to Dolby 5.1 or PCM mode in the Disc Menu.
switching regions:
    • 1
Turn on your DVD player.
    • 2
Open the DVD player's main drive, also commonly called the DVD "tray." The region cannot be changed while a DVD is in the machine, so many DVD players require the tray to be open as an extra precaution.
    • 3
Push "Info" or "Setup" on your remote.
    • 4
Use the remote to select the "Region" option as indicated on your TV screen.
    • 5
Select "Region 9" to change the system to multiregion formatting. Regions 1 through 8 represent specific geographic locations and will not allow multiregion playback.
Oct 30, 2013 | LG Televison & Video
Samsung HT-F5550 and cinavia audio problem any solution plase
help my player blu ray its get cinavia code message 3
Sep 15, 2013 | Samsung Televison & Video
Televison & Video Logo
240 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
