First, unless you are a trained or self-taught audio technician, don't attempt to repair the unit yourself. Let the professionals repair it. You can damage it beyond repair if you don't know what you're doing.
Non-working channels are caused either by bad connections, bad solder joints or a dead IC op-amp.
The causes of weak channels can be more challenging to track down. I'd suspect bad connections, dirty controls or connectors.
SOURCE: No volume control with 2 faders on Mackie CR1604 mixer
If all other functions work for those channels, the most likely problem is the fader itself. These can fail and operate more like switches rather than faders. Without witnessing the behavior, I can not state that for sure. While these mixers are not the hardest to work on, they are time consuming. The faders can be purchased from Mackie directly. If you need to have this repaired, any shop that repairs audio gear should be able to erpair this for you. Where are you located?
Dan
SOURCE: Ch. 10 does not work - Mackie 1604-VLZ PRO
Yes, the ribbon cable is the 1st thing I would check. You can check the ribbon like this: Disconnect said cable from the channels. Connect cable connector from a known good channel to the problem channel. If channel sounds the same trace a signal through the channel op-amps.
SOURCE: mackie cr 1604 clip light stays on constantly
Is the PFL button stuck down on these two channels ?
SOURCE: Mackie 1604 VLZ3 Issue.
Hi kielhunt
It sounds like power supply issues.
You may have bad capacitors and/or bad regulators.
If you have a multimeter you can get in there and check the dc voltages for ripple(ac voltage mixed with dc) or over/under voltages along the +/- 15volts lines.
Good luck
Testimonial: "Good ideas, even though he didn't know the answer to the issue fully he was well rounded enough to give great ideas for in-house solutions!"
SOURCE: My old CR1604 mackie mixer
If the hum is observable in headphones, then it is likely a power supply problem, usually a dried out electrolytic filter capacitor.
