SOURCE: Hampton Bay Remote
Hampton Bay Almeida 52" Ceiling Fan 52101916 ... Had fan installed remote fan would not go on ... nothing not even light ... changed batteries electrician that installed it said take it back to the store he would install another fan .. just bought fan last year HELP
SOURCE: hampton bay altura 68
Read this on another thread - apparently the solution came from HB's tech support.
Turn the fan speed to HI and then select Reverse. You should hear a "click" and see the fan reverse direction. It seems that the reversing relay only works when the fan speed is set to HI.
Good Luck!!
Two Metre Man
SOURCE: Hampton Bay w/ remote and will not reverse.
To eliminate this problem and any humming noise, remove any wall switch that turns off and on the fan, just remove the switch from the line and use the remote to operate the fan.
SOURCE: Hampton Bay 52 In. Clarington. How do I reverse the fan?
Try these two: 1) look for a small switch up near the light area on the dark-colored area of the fan. If a switch is there, then simply flip the switch to the other position; 2) if you have a remote control for the fan, the reverse mode may appear on the remote control. Hope this helps.
SOURCE: how do you reverse the direction on this model of ceiling fan
I have this exact model, and have been so disappointed with the answers everyone has been giving about things they don't know. On the top of the fan, about one inch away from the center cover plate (the plate that slides up and down for looks, that is around the down shaft) run your hand around about two fingers wide, you will find a switch, RECESSED into the housing (if you are not feeling very carefully you will think it is just a normal opening in the housing. This will fix your issue, Unless you remove the fan or your head is crammed against the ceiling, you will NOT see the switch.
