SOURCE: kemore Dryer 11064602300 belt replacement
Go to repairclinic.com. Click on the "Repair Help" heading on the left-hand side of the screen. On the next page is a "Dryer Belt Diagrams" heading on the left hand side. Your dryer belt diagram will be either "H" or "K" listed under the Whirlpool section. Your Kenmore is manufactured by Whirlpool. I hope this helps you. Please post back if you need further assistance.
SOURCE: Kenmore dryer (electric )
NOT ELITE HE4..... Model 96595400. Replaced thermistor and Hi-Limit Stat. Probably the thermistor.
SOURCE: Kenmore electric dryer vibrates loudly
Yes the kenmore uses the roller wheels . dr fixit in the service providers has them. Any way I can help otherwise?
SOURCE: Replacing the belt on my kenmore electric dryer model # 110.8756.
Depending on the type of door the dryer has, is how you approach the
access of these dryers. Mostly though you yank out the filter
first.Remove the 2 screws in the filter housing on top.Then use a putty
knife to pop the top. Remove the screws holding the front panel on.
VERY IMPORTANT! Raise the front up an inch before pulling forward or
the panel clips will break! Some models have a panel on bottom. If they
do then this panel must come off first. Then you remove the door
springs and back off the screws holding down the bottom of the door
panel. Then pop the top and remove the screws on top to get the panel
out of your way. Get the drum out and clean out the dryer. Oil the wheels and idler. Replace the belt using this diagram . NOTE yours is lower right:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Kenmore electric dryer shuts off after 5 minutes and won't restar
when you try to start it again do you hear a humming comeing from the motor? can you jump start it by turning the drum while holding the start button? If you say yes to these questions you have a bad motor.
