Question about Hitachi Televison & Video
Ihave a Hitachi model L32A403 is it digital ready? OR Ddo ni need a converter box, Cannnot get signal strengh it is grayed out.
  • Hitachi Master
  • 5,833 Answers
According to the specifications, https://www.cnet.com/products/hitachi-l32a403/specs/ , the Hitachi L32A403 has a digital (ATSC) and an analog (NTSC) tuner. Check if the input/source is set to TV. The signal strength information will only be available if you are using the digital tuner. This TV has an Input button on the TV and on the original remote. (It's the second from the bottom on the side of the TV, between the power and menu buttons. On the remote, the Input button is above and to the right of the arrow/Select keys. The Menu button is on the left side of the remote in that same line.) Press the Input button and then use the arrow keys to highlight the desired input; press Select to go to the input. On the TV the Channel Up/Down buttons are the same as the Up/Down arrows on the remote in this menu. The Volume keys will work as Left/Right.
Make sure to set the Channel Source to Air before attempting to scan for channels and check the signal strength. The Channel sub-menu is at the bottom of the list on the On-Screen Menu, after you press that button. However, this menu is not available if the input isn't TV. See the manual here: https://www.searspartsdirect.com/partsdirect/user-manuals/l32a403-hitachi-parts-manual .
Since digital signals are either enough to be seen by the tuner or give no signal, make sure that you use the best antenna appropriate for the distance and frequencies being broadcast in your area. Point the antenna in the correct direction. See http://www.antennaweb.org or http://www.tvfool.com for information on the stations near you. Antennaweb gives a very conservative list even though it assumes an external antenna.
I hope this helps.
Posted on Nov 06, 2018
SOURCE:
SOURCE: Sansui TVS273
This tv is not digital.
Posted on May 12, 2008
tvguy171
  • 106 Answers
SOURCE: my ge tv digital ready?
Your TV is NOT digital ready. IF you do not have cable or satellite, you will need a converter box. If you do have cable or satellite you have nothing to do or worry about as the cable or satellite box will automatically do the conversion for you. Hope this helps
Posted on Dec 20, 2008
AZSkiBum
SOURCE: Need help locating a box to make my TV receive true HDTV
Your Hitachi 43FDX01B is HD-Ready, which means it has high definition capability, but it needs an HDTV Tuner added to it. DTV converters can only give you Standard Definition resolution. You can browse HDTV Tuners Now for the different types of HDTV Tuner that are available.
Posted on Jan 01, 2009
  • 56 Answers
SOURCE: Polaroid Model TLX01911C
Greetings!
This set is listed as having the ATSC (Advanced Television Systems Committee) tuner. This tuner provides reception of digital over-the-air (antenna/rabbit ears) signals and would therefore not need a converter box fir that use.
If you are trying to receive un-encrypted digital signals from cable, the ATSC tuner does no good. The set would then require a QAM (quadrature amplitude modulation) tuner. I am not sure if this set has a QAM tuner or not. Even if it did not, your cable provider must provide a way for you to receive their signal and should make their converter box available to you.
Hope this helps explain things a little,
Rob
Posted on Jan 14, 2009
  • 83 Answers
SOURCE: Is my Sanyo DS20930 digital ready or will it need a converter box
if it was bought prior to 2005 it may not be, if it has freeview/freesat in it then it will be digital ready or if you have sky/virgin then you will be ok
Posted on Jan 24, 2009
Does a hitachi 42 inch need a converter box to be able to watch regular tv
Which model do you have? The ATSC tuners were required in 42" TVs starting in the middle of 2005. Some Hitachi 42" TVs built before that date have an ATSC tuner but other models do not. The ones that didn't were usually called HD-ready TVs. For those models, you need a set-top box to receive OTA signals (except for some low power stations that continue to broadcast an analog signal).
If you provide your model number, I'll try to confirm the tuner information. If you look at the model information plaque on the back of the TV, you will see some information about when the unit was manufactured. If it was built in 2006 or later, you can be sure that the unit has a digital tuner.
I hope this helps.
Nov 23, 2014 | Televison & Video
Is this tv digital ready?
The Hitachi 61SDX01B only has an NTSC tuner (analog). You will need a set-top box to watch digital (ATSC (OTA) or QAM (unencrypted digital cable) signals. For OTA signals, the digital-to-analog converter boxes that were sold with the government coupon were limited to SD output. HD converter boxes are available but cost more.
I wish that I had better news for you.
Sep 14, 2011 | Hitachi 61SDX01B 61" Rear Projection...
I have Hitachi model,L32A403 it does not pick up any digital signals. What type of antennea can I buy? please help!
Your TV doesn't matter as much as where you are and what might block your signal. Go to antennaweb.org or tvfool.com and plug in your address. These sites will tell you what OTA stations are likely to be available if you point your antenna in specific directions. Antennaweb assumes an outdoor antenna and is very conservative in the channel information (gives me 2 stations 10 miles away and I get 10 (those 2 and the rest from 30 miles away).
tvfool.com gives more details (and antenna strength information). Use this data to choose your antenna (green, red, purple - listed on the box or sales spec sheets in most stores/online stores). Add an amplifier if the signal is split between several TVs.
I hope this helps.
(the tuner does matter a little; a great tuner gets more channels with the given signal strength. With digital signals, you either get enough signal to view the station or it's out.)
Jul 26, 2010 | Hitachi Televison & Video
I would like to know if the Hitachi 51UWX20B television can be connected to the internet.
Your Hitachi 51UWX20B is an HDTV-Ready TV. No Digital Tuner. HDTV-Ready means that your TV set is capable of displaying analog and high-definition digital pictures, but without a digital tuner, it cannot receive the digital signal. An HDTV-Ready requires an external high-definition TV receiver (digital tuner) in order to receive HDTV signals. These external receivers can be called an HDTV Tuner, set-top-box, decoder or DTV Converter Box . So you will be required to purchase a converter box to receive over the air programming from an external antenna.
Jul 03, 2010 | Hitachi 51UWX20B 51" Rear Projection...
I cannnot receive digital stations.
your tv must be dtv ready or u will need a converter box or cable
Aug 05, 2009 | Sharp Televison & Video
Digital TV Ready?
I believe you need a converter box. Im pretty sure this unit only has a NTSC Tuner. Recieving HD would be via Componet Inputs or DVI. If a HDMI Input is available you could use it too but I think it only has a DVI connector.
Hope this helps,
Skyassoc
Jun 19, 2009 | Hitachi 57SWX20B 57" Rear Projection...
Is my Hitachi 61uwx10b ultravision hd ready digital tv ready when they switch over to digital vrodacasting or will i need a converter box,
This TV will need a converter box. It was made in the days before the digital tuner was required on big TV sets.
Just remember the converter is only needed if you get off-the-air reception with an antenna for local channels. If you have cable or satellite and get your local channels that way, you don't have to do anything. The change to digital will not affect you.
If you are now using rabbit ears or an old worn-out outside antenna, you might think about upgrading your antenna when you get a converter box. Signal strength is very important with the new digital broadcasting. Too weak a signal means no picture at all or one that freezes up or turns blocky. The antenna that worked for analog may not be adequate for digital.
Jun 06, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi 57G500A DTV & upcoming analog to digital changeover
To answer your direct question, yes it has a digital tuner. To answer your real question, NO it WILL NOT receive the new ATSC (digital) broadcast stations. The tuner itself is a digital one but works only for analog signals. The changeover in February will change the broadcast signals to a new digital format that will require a converter for your set to continue to function. Please note that the converter is only required if you receive your signal from rabbit ears or a rooftop antenna. If connected to cable or satelite, no change will be seen and no converter is needed.
To simplify:
Over air reception = need converter
Cable or satelite = no converter
Dan
Jan 28, 2009 | Hitachi 57G500 57" TV
Is my tv digital already or do I need a converter?
Your TV does have a digital tuner in it already. Also a converter box is only needed if you use an Antenna to recieve TV. So if you have Cable or Satillite, you will not need a box at all.
Jun 04, 2008 | Hitachi 51G500 51" Rear Projection...
Televison & Video Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
