SOURCE: How to set an Armitron WR330 Watch
he following labels are on the inner ring of the watch; I've given
their positions relative to where numbers would be on the face of an
analog watch.
"ST/STP" is at 2:00; "EL" is at 4:00; "MODE" is at 8:00; and "ADJ" is at 10:00.
To set the time, date, and day of week:
Press and hold in the "MODE" button until the display starts flashing. (This is the alarm time.)
Press the "MODE" button again; the seconds begin flashing. Press "ADJ" to set them to zero.
Press the ""ST/STP" button to change what you want to set. The
options appear in this order each time you press the "ST/STP" button:
minutes, hour, month, day, day of week.
Use the "ADJ" button to change the value of the setting.
Touch "MODE" to save the settings and return to time mode.
The website listed below has many instruction sheets, but does NOT have instructions for this watch as of 25 December 2008.
Check:
http://www.armitron.com/WatchInstructions.html
SOURCE: setting Armitron Watch model WR330
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all ARMITRON watch manuals. Rate me, please.
SOURCE: How to set an Armitron watch. Can't set the days correctly.
mcdevito75 here, The stem has 2 positions, Carefully slip a fingernail under the stem and lift, it may take a few trys to get used to it, in this first position you should be able to set the DATE very easily and Maybe the DAY of the wwek also, turn the stem 1 way to change the DATE and the other way For the DAY of the week., Let"s figure you can only set the DATE in this first position, First thig to do is set the DAY of the week, go thru the watches 24 hour cycle and set the DAY to 1 DAY before the DAY you need, now in that first position of the stem, set the DATE to 1 DATE before the DATE you need, now in the 2nd position we all know pull the stem out to set the time of day, go thru the 24 hour cycle to bring up the DAY of the week and DATE you need. Now your watch is set and will change on tome at around mid-nite.
SOURCE: how do I set the
Thanks for contacting FixYa.
You can find a manual here:
http://www.armitron.com/watch_instructions.asp
Best regards. Jewel
SOURCE: how do i set the
Hi an_stocker0,
There is two pulls to set the time and date .First pull is for the day / date wind it in order to choose the right date number and second pull is for the time wind it until the desired time comes out. For better understanding follow this link for more information and instructions below. Feel free to ask whatever the results.
http://www.armitron.com/docs/Automatic%20Manual.pdf
Hope its may helps;
Regards,
VOTIT
Testimonial: "thanks "
