It seems to be running all the time.
Well for 42 years its done good. it's more than likely the gas needs replacing if the motor is still working, surprising to see one still going this long.
Thank you! By gas, do you mean Freon? Should I have it fixed? I think that it’s still running because it’s never been moved.
the old one work off a different type of freon gas but would think it could be worth, 20 to 30 years is the most some last. but its like any gas it turns to a dust over time so would need a freon flush to clean the pipes out.
No don't have it repaired. One thing you need to check is the fan in freezer compartment. It's usually right behind a vent somewhere in the freezer. When you hear motor running feel if you feel air blowing in that freezer. If no, access that fan and try tapping the blade with a piece of wood. NO METAL! May get it started again that way but it won't last. The fan can be found in a sidewalk junker and replaced free. That's as far as I'd go on a fridge that age. You can also contact the power company in your area. I know where I live they'd exchange that fridge for a new one free of charge. A energy rebate program. A repair guy will charge you a fortune if he will even touch it at all. Don't think the freon in a fridge that old is legal anymore. You get a crooked repair guy over there and he'll try charging you to convert it to the right freon and every other crooked thing he can rob you on. The fan, if it isn't that it's over.
Time to replace it.
SOURCE: Food freezing in frig
Go to the link below and the choose line 22 and click it. That link page helps identify most common problems you may have with your refrigerator, Thanks Sea Breeze.
http://www.applianceaid.com/refrigerator.html
SOURCE: GE Profile Stainless Steel Top Freezer Refrigerator
Check the compressor.
Unplug for 15-20 min. plug it back in and listen for the compressor to start. You will have to be behind the ref to listen and make sure you hear the compressor start and not just a fan running. If you hear a clicking noise then the compressor relay is bad.
SOURCE: Side by side GE refrigerator freezing food in refrigerator.
The unit is having a damper control issue. In the back of the refrigerator there is an assembly that is in the center at the top. It connects to the freezer side. The damper is broken, cracked or has an obstruction. Check this and see if it is the problem.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/robert_e97a69269ae71345
SOURCE: 48" ge monogram refrigerator not staying cold
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong.
If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
sfjfg
