Question about American Standard Home
How do fix my American standard cadet 3 toilet?
Help! I have an American Standard Cadet 3 #4021N 4.8 LPF 1.28 GPF there is a bar code # 7930956475. Have replaced all the seals. I've also replaced the lapper at least five times I've tried them all, from fluid master, American standard # 7381026-400.0070A, TOTO, Korky. My toilet flapper still leaks. I am at a loss. I want to replace the flush valve assembly in hopes that this will stop my toilet from loosing water. I don't know which one to replace it with. I suspect that the flush valve assembly that's in there is not an American standard product. I have measured the hole in the tank, it measure 4". all the flush valves with the exception of the one piece toilet flush valves are 3". Will the AS 738921-100.00toA 3-inch flush valve assembly work with this toilet? I'm about ready to replace the toilet itself. Thanks!
  • Steve Pack
    Steve Pack Nov 04, 2018
    Hi Esther Duffy, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? go to home depot or Lowe's, the 4 inch valve goes to champion., there is a seal kit that can be placed over existing opening
  • Esther Duffy
    Esther Duffy Nov 04, 2018
    where can I find that seal? I've been to Lowe's and Home Depot but have not been able to find anything that will work. Looking into getting a new toilet.
  • 5,926 Answers
Toilets wear out from mineral deposits. Fixn may cost more then new. Googl used commodes first
Posted on Nov 04, 2018
SOURCE:
SOURCE: Toilet Refills Every 15-Minutes
I have minute amount of leakage into the bowl causing mold to grow. I believe that it may be the rubber seal for the flapper body to the porcelain.
Posted on Jan 10, 2009
  • 687 Answers
SOURCE: flapper will not go down
Troy, the flapper otherwise known as the flush valve is easily replaced. They are also very inexpensive. Sometimes they can become distorted due to the clorine in the water and won't operate in the same way they did when it was new. I bet this will fix your issue and save you money as well.
Posted on Mar 21, 2009
snap101
  • 117 Answers
SOURCE: Flush valve drops before bowl completes flush
is the flapper weighted? if it is it will cause it to shut prematurely. one thing you can do is increase the water in the tank. you might have to buy a pvc cuppler to put on the over flow to allow it to fill up more. korky makes a nice flapper thats not weighted
Posted on Aug 01, 2009
jeff_drakesr
  • 155 Answers
SOURCE: Yellow attachment to flapper in Cadet 3 toilet tank
Some toilet flappers are designed with this some are not. It has to do with the particular flapper design, helping the flapper to stay in the open position to allow a better flush. Anyways you should be to adjust this float up or down to optimize it's usefulness. Trial and error is all you can do, keep watching and flushing until it no longer gets in the way. I hope this helps in at least knowing that for your toilet and the flapper you have, it's suppose to be there. Good luck and thanks for using FIXYA and have a great weekend. Jeff
Posted on Apr 09, 2010
  • 5 Answers
SOURCE: Porcher 6.0 Lpf / 1.6 toilet. Plumber said he
Try replacing the flapper, they are cheap and so long as the tank and or bowl are not cracked you can replace all of the internal parts and basically have a brand new toilet much cheaper then replacing the entire unit. Go down to your local hardware store and everything you need is in one simple kit with very simple instructions. Good Luck.
Posted on Jul 22, 2010
Do you turn the screw to the left or right on a american standard toilet to adjust the water level in the toilet tank
Usually to the right will drop the float, deceasring the water level, left will increase the water level.
Aug 25, 2014 | Cadet Manufacturing American Standard...
My brand new toilet american standard round front model cadet 3 tank not fill water
If you verify that the water supply to the toilet is turned on, push down the float on the flush valve. Water should start flowing. If it doesn't, something (such as debris) may be blocking the valve and preventing filling. The new valve could be defective - permanently closed.
Jan 11, 2013 | American Standard Cadet 3 Right Height...
American standard caded 3 leaking water from tank into toilet and occasionally running every 5 minutes. is this a flapper problem (it seems well seated) or could it be leaking elswhere?
It could be a bad seat around the flapper or the flapper itself. Replace flapper with one designed for the Cadet. Check water level and see it doesn't flow above the overflow tube. if it is above the tube lower the float ball by turning the screw at top of ball.
May 03, 2012 | American Standard Cadet 3 Right Height...
I have a american standard cadet 111 6liter elongated toilet. I have replaced the flaper and the rubber seal in tank and I still have a problem with the toilet refilling itself after a hour or so. Any...
To see where the water is going, place some red cake dye in the tank and see where the water turns red....this will show you exactly what is happening and where the water is going...
heatman101
Feb 22, 2011 | American Standard Cadet 3 Right Height...
I just installed an american standard cadet 3.Home depot rated this toilet as a 10 for flush power. when I flush 1st off the flapper wont stay up on it own long enough to flush,2nd if I hold it open it is...
We have just recently purchased one of the American standard cadet at home depot from a discount flyer and had it for about a day and took it back.
Like you said, Did not notice Any thing like a strong flush.
RECOMENDATION:
Take it back.
Home Depot also sells a Kohler Toilet 1.6 Gallon Flush Install
This is all it said it was. It saves water for sure and has a quick flush.
We liked it so much we purchased two of them because everyone in the house only wanted to using our bathroom.
Hope this tip helps.
r/
David
Feb 24, 2010 | American Standard Cadet 3 Round Toilet...
Toilet flushing problem! I purchased an American Standard Cadet 3 High HET toilet (1.28 gallon). When I flush the toilet, the flap will not stay up to allow the water to drain from the tank. When handle is...
The siphon mechanism works on a vacuum principle. If there is the slightest damage to the siphon membrane you will experience the problem you describe. A new siphon is required.
Dec 31, 2009 | American Standard Cadet 3 Right Height...
Need to know which cadet to install--3 or 4
I only install Kohler commodes and have never had a problem with clogging. All of Kohler commodes have a 3.5 inch flush valve, just pick the style you want.
Jul 08, 2009 | American Standard Cadet 3 Right Height...
Home Logo
135 people viewed this question
Top American Standard Home Experts
US Parts Center
US Parts Center
Donni Steen
Mike
Are you an American Standard Home Expert? Answer questions, earn points and help others
