SOURCE: I have a 5 hp
the inside the card is plugged it needs to be removed and there is a pin sized hole in the brass bowl nut about a 1/4 of the way from the top i use 1 strand from a wire brush to clear them also all hidden pasages inside need to be cleaned with carb cleaner and checked with a compresed air source to make sure they are infact clear and flowing. a can of dustoff will work if you dont have a compressor
SOURCE: looking for parts diagram for
try http://www.ereplacementparts.com But your quote model doe not come up. Maybe U have another number. Works on part numbersModel numbers and Snow blower and select manufacturer. Regards Henry PS if you find the model usually exploded views of equipment.
