Hello, do You try this three things:
1. If there is no power to your Smart Scoop®, make sure that the AC power supply is plugged into a working outlet.
2. Next, make sure that the breakaway power cord is connected properly.
3. Finally, verify that the clutch is in the locked position (turn it counter-clockwise). Smart Scoop® will NOT operate if the clutch is not locked.
I repair a lot of laptops. I have found through the years, that they all seem to follow a basic disassembly pattern. Although access to the cooling tube/heatsink/fan combo, and processor, for some of the laptops, is through the bottom, it is just for those hardware components.
To disassemble these type of laptops, you still have to come down from the top.
One laptop I have so far not had the fortune of working on, is a Balance Digital Technology laptop.
I 'googled' a few models just now, and they look to be the same as many HP, or Compaq, or IBM, or Toshiba, or on and on, models I have worked on.
The first thing you need to do, is remove the AC adapter, (if plugged in), and the battery.
Then turn the laptop over, and remove the harddrive, the memory compartment cover, and memory modules, (ram sticks), and any other removable compartment cover, or removable device.
I use a clean egg carton, and label each egg holder as to where what area, the screws came from, and put the various screws in these egg holders. There may be as many as ten or more, different types of screws, and could be up to 50 screws or more.
(Doesn't sound very 'Techie', huh? I work on a lot of laptops, and can just throw these egg cartons away when done)
I also suggest you use a digital camera, or video camera, and good lighting, as you go along. (If available) Helps to reference later as to what went where, and in what order. I also suggest making notes and drawings. Make them legible enough so that you will understand them later.
Turn the laptop over to it's normal position. There is a plastic strip above the keyboard. It's under the LCD screen. This strip may have speakers in it, and/or LED lights.
This plastic strip has tabs going around the edge of it. These tabs keep it snapped in place. I take a flat tip jewelers screwdriver, and ease it in a little bit, where the plastic strip meets the body of the laptop. Just get it under the edge, and carefully pry up. If you can't get it in, move over. You might be right at where one of those tabs are.
You may only be able to ease it up just a little bit, and have to use another small flat instrument to hold this raised part up. Then take your flat tip, and go to another place close to it. Try to pry that part of the edge up.
When the strip first pops up, it comes up with a "Crack' sound. You'll think you broke it, but you could run a truck over this plastic part!
Each time you get the strip up, and a tab comes up, 'Crack'. Kind of unsettles your nerves until you get used to it!
Work around the edge of this strip. Keep popping it up as you go around. Eventually it will come up and off. Look for wires. There are small plastic White connectors. You can ease these little connectors apart with your fingernails. The connectors are different sizes, and have different pins. There's no mixing them up when it's time to reassemble.
The hard part is over now. You should see a screw, or screws to remove the keyboard. It comes up at a 45 degree angle, and is removed at this angle. NOT straight up! After you get it up a little, BE careful! There is a tiny wire harness that the connectors need to be taken apart.
Now you should see a metal shield. This has screws. After this, you remove all the screws you see, and remove all the case screws from the bottom side. Look for 'hidden' screws in the memory compartment area, and the other compartments.
The LCD screen hinges will have plastic covers on them. There may be ascrew that holds each cover on. Most of the time they pop off, like the flat plastic strip did. There will be screws on the front side ofr the LCD screen hinges, and screws on the back side. They may have rubber covers over the screws. They are usally held on with a type of rubber cement. You just take your flat tip, and ease them off.
SOURCE: Andis Ultra Edge Pet Clipper Assembly Help
I took my andis ceramic edge blade apart to clean. Now my clipper will no longer cut my dog's hair
SOURCE: unlock a Philips portable DVD Player Pet 741/37
It worked for my Philips PET741/37:
1. Power ON the DVD player without a DISC inside
2. Press the skip keys in this order (the keys are under the "disc menu" and "stop"): right, left, right, left, right, right, left (YOU DON'T HAVE TO GO TO SETUP MENU, just do this in the "blue screen".
3. It will show a menu with region, now use the arrow keys to select "region" and change to "test 0" (all regions).
4. Press OK to confirm. Enjoy
Silmara
Testimonial: "Easy and Very helpfull ... Thanks a lot for your help. "
SOURCE: can i get detailed instructions to reassemble
Same problem here. Wish there was instructions online somewhere.
SOURCE: How can I train my cat to use the litter box?
Cats learn quickly how to use litter boxes. Keep an eye on your cat at first and after waking up or eating, place your cat in the litter box. If you see your cat squatting, this would also be a good time to place him/her in their litter box. If they happen to have an accident outside the litter box I suggest wiping it up with a paper towel and placing it in the box. Then take your cats paws and place them in the box - this way they will associate what they have just done with the place where they should be doing it. When they successfully use the box for the first few times, make sure to praise them.
Self-cleaning litter boxes are increasing in popularity and
are available at most local pet supply stores in your area or online. Here are a few places for you to search and
compare.
http://www.petco.com/product/100832/ScoopFree-Automatic-Self-Cleaning-Litter-Box.aspx
