SOURCE: How do you adjust the belt for a Weslo Cadence 815 treadmill?
Hi, I don't have a manual on your particular treadmill but most all treadmills use the same type of belt tension and tracking, which is an allen screw adjustment on the rear tension bar. One on either side. You should have been provided an allen wrench with your treadmill, if not then use one of your own the proper size. Make the adjustment with the unit running at its slowest speed. Clockwise tightens the tension and will draw the belt. Good Luck, this should Fixya!
SOURCE: manual for Schwinn 1600 Treadmill
You can try
E-mail: [email protected]
Phone: (800) 868-5764
Customer Service Hours:
Monday-Friday: 6AM - 5PM PST
Saturday, Sunday: Closed
Testimonial: "quick response and good solution advice of next step in finding a solution"
SOURCE: I have a Schwinn 815
A friend of mine gave me thier treadmill for this exact reason. I took it appart and the problem was a blown fuse on the board in the motor compartment. It is right below where the main power goes into the board and if it is blown it should appear white. I replaced it and the treadmill works good as new!
SOURCE: Belt slipping on Schwinn Treadmill 5620P looking for local repair zip code 97405
Look for a repair person in your area at Treadmill Repair
If you don't see one there, and find a good one somewhere else, please submit them to this directory.
