SOURCE: Scanner Driver
Download & save the XP driver from driverguide website (link) :http://www.scanner-drivers.com/drivers/123/123132.htm or use this direct link for the exe file : http://members.driverguide.com/director/dispatch_getfile.php?did=123132&time=1201177794&auth=75a352b3fab77696d93d8bfb8976a4f3
Now using winrar or similar utility, extract all the files from the exe to a folder on your hard drive, connect the scanner to computer and when Vista asks for drivers, point to this folder. If you already have attached the scanner, you may go to device manager and update the driver.
Normally this should work
SOURCE: can't find driver for may scanner artec e+48u
You can find your drver on download.com once you are on the web site search by procut number (e+48u) not model.
SOURCE: Need driver for Artec e+48u compatible with vista
I've used this scanner on both Windows Vista and 7 by running the driver installation from the original disk in Windows XP compatibility mode and then plugging the scanner in to the computer.
SOURCE: need driver
Hello i hope u 'll be fine.
You can get the driver of Artec E+ 48U USB Scanner 4.12 for all operating systems like Windows 98/ME/2000/XP
When u click on any above link downloading will start. After downloading driver, Install it on Your PC and Enjoy
Wish u good luck
If it is helpful, Kindly Do Rate Me
Thanks for usingfixya.
