Question about Casio Music
I have disassembled my Casio CDP 100, how do I take the key out..
3 Suggested Answers
SOURCE:
SOURCE: I have a CDP-100 and need disassembly instructions
I just fixed my CDP 100 which had a similar problem - dropped and two keys not working up one end.
1. Lay keyboard upside down on soft surface. Under keyboard is plastic cover held on by 17 screws. Remove all these and lift cover away. The metal key ends are all revealed.
2. Locate the disloged keys. Carefully press them back into position - they will "click" into place. Make sure the corresponding key on the keyboard isn't stuck in an "up" position - you may have to remove the metal key part and replace it again while making sure the key is correctly seated.
3. Replace cover and screws.
Posted on Sep 09, 2012
  • 3154 Answers
SOURCE: I have a Casio cdp 100 keyboard and two of the keys are stuck in the down position. Almost like the spring has gone in these 2 keys. Can this be fixed and if so, how?
Ordinarily there is a separate spring on each key attached to the rear of the key that sometimes pops loose or the attachment point breaks off. However as Casio describes this as "springless action" that leads me to beleives it has a weight attached to the key instead of the spring setup. ROland used to use that sort of action and had a lot of problems with the weights coming unglued.
At any rate You would need to take the instrument apart enoug to get to both sides of the action top and bottom. Frankly, it's no fun and I'd suggest taking it to. An authorized Casio service center. You may find it's a recall problem, but if not, the service center will have a better chance of getting Casio to ship them the parts than you would.
Posted on Aug 01, 2016
is it under warranty ?
if not
you may have to contact your point of sale to find their local repairer
if you cant un stick them yourself that keyboard will have to be taken apart
are the two keys ... white keys or black ...nearby or way apart
do the two keys drop loose..and lift up
or stay down
example will vacuum cleaner suction help lift the stuck keys or not
sales blurp says this
A spring-less hammer system
Scaled Hammer Action Keyboard
https://www.jbhifi.com.au/musical-instruments/casio/casio-cdp-120-digital-piano/91120
Jul 31, 2016 | Casio Music
How do you replace a key on a casio 100 keyboard. which screws do you remove in the back
What kind/type of your Casio 100?
Casio MT-100,LK-100,CA-100,PT-100,CDP-100 ?
May 19, 2015 | Casio LK-100 Keyboard
Note not functioning
Possibly dust. May need to make an appointment to see Dr Casio if you haven't got it fixed yet
Sep 24, 2013 | Casio Cdp-100 88 Note Digital Piano
I have a CDP-100 and one key isn't working. When pressed there is no sound
you must open the case and change the rubber contact under the key isn't working
Mar 16, 2013 | Casio Music
Disfunctioning f note. It plays extremely loudly.
If it is under warranty, may as well make use of it. In the long run it will be less headache for you.
It is something that should be repairable, although time consuming. as it is likely a stray bit of solder lodged where it should not be.
Feb 06, 2012 | Casio CS43 Stand for CDP 100
How do i fix a dead key on my casio cdp 220r keyboard?
I’m repairing a casio cdp-220r for the same reason. The F3 key does not sound at all and some adjacent keys sound louder than the rest at normal play attack. I will have to replace the entire octave memebrane as I found that it was broken when I finally got access to it. See phot
Dec 31, 2011 | Music
I have a CDP-100 and need disassembly instructions for access to internal keyboard assembly. Unit was dropped while unloading from car. Now some keys are akimbo and won't play as though they are off their...
Feb 22, 2010 | Casio Music
Music Logo
153 people viewed this question
Top Casio Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Casio Music Expert? Answer questions, earn points and help others
