Regency R1077 base scanner can not delete old frequencies to reprogram scanner
Press "Manual", then press digit key ("0/10" thru "9") that corresponds with the channel to be changed ("0/10" = ch10). Next, press the digit and decimal point keys to enter the frequency in megahertz (Mhz) to be stored in the channel. To store 453.100 Mhz in channel 2, you would press "Manual", then "2". Press the following keys in order: "4" "5" "3" "." "1" "0" "0", followed by pressing the "Enter" key. Repeat this process for up to 10 channels.If you wish to clear unused channels, you should be able to select the channel, then enter "." followed by the "Enter" key.
This scanner will only accept frequencies between 30.000Mhz and 599.999 Mhz. Attempting to input frequencies outside this range will result in an error message.
I hope this helps and good luck! Please rate my reply. Thanks.
