Steaming from whom,. netfilx, vudu, hulu ,. who?
if only one is bad, them maybe they have problems today.; (yah)
Acer Swift 3 Intel Core i5-8250U 8GB 256GB SSD Windows 10 SF315-51G-51CE (Gen8 intel processor !)
this? (yes/no)?
if yes, then you will NOT need more RAM, 8GB is more than plenty. really the PC is perfect, if not INFECTED .
Let me guess, streaming with Windows EDGE browser?
what internet connection do you have,, HOME to ISP.?
DSL, cable, Fiber, satellite. ?dial up (lol) or 3/5G ?
(case in point my cable modem comes is 16 speeds.
speed x1 is no good, or streaming will fail. (shows buffering and stalls, endless...)
I pay big money for x16, no stall and TV and gigalan in all rooms all wired, and never chop for years.
the endless WIFI BLUES:
is you local internet connection wifi or is it Ethernet cable.
the later is a test use the cable to the router, and If that works ok. your wifi has problem.s
wifi , can be very problematic (google it and read endless problems )
if wifi , move close to your Router, if that makes streaming work better you learned how weak wifi is (it's radio technology)
if wifi is overloaded in you highly populated neighborhood
use a higher channel. (a router setting) do you own your own router, or does the ISP own it. (sorry but networking is not simple)
in the PC , see what startup programs are running,
run taskmanager (control+alt+delete)
see startup tab.
disable thing there you don't need.
(adobe update, etc, most with update in name disable them) lean this down.
best is test wired first,
ok>?
if wired works and wireless fails
then we go the long hard road of diagnosing wireless , here in a text box. (blind)
wireless loves to fail. that is what it is.
google wireless sucks and read.
but if you live far from the big city
and are close to your router wifi.
then it works, ok. mostly.
but NO ISP stated, at all.
for streaming to work you need some bandwidth.
google and run speed test yet?
did you run say Netflix speed test.
this tells you what streaming modes will best work for you.https://ispspeedindex.netflix.com/countr...
Netflix and others also allow you to run lower density videos. that do not need high bandwidth, HD and not UHD. see?
try wired Ethernet first.
if that fails say so first
its only $5 cable, to buy, and test .
choppy has many causes. ( a short list)
ISP issues. (connections to the web bad)
PC issues, lots of background processes running that must not be.
PC infected.? malware etc.
WIFI is overloaded in your HOOD, (run Inssider app v2 free try higher channels?yet)
PC too far from your router of blocked by brick walls, or using 5Hz band only. is 2.4Ghz turned off by mistake in the router.
in the home some appliances can jam wifi.
(huge list ask) like old landline phone sets.
or baby monitors and more. lots.
Increase the speed of your internet connection. Add some memory to your computer too.
