Question about Riccar Vacuums
Well I have the four screws out of my 1500 PV Riccar but how do I release the switch on the tank
My riccar 8955. If I lift it off the floor while it is running it shuts off. What's up?
Your 8955 could be as old as 18 yrs. Try tightening the screw holding the handle in, it could be loose allowing the handle to move back and forth enough to keep the switch from activating.
If it's an older vacuum or is used heavily it could have cracks in the body where the handle screw attaches or some damage inside the vacuum body where the handle bottom goes into.
If that doesn't help, Remove the bag door, remove the screws at the top to remove the cover to gain access to the area where the switch and wiring is located to inspect for the cause. When you push the lever at the top of the handle a lever going down activates the switch. It doesn't take much play in the handle to make the switch go on and off.
Apr 21, 2018 | Riccar Vacuums
Replace power cord on riccar 8955
Remove the bag door cover, remove the screws holding the cover over the switch and wires coming into the body of the vacuum. Remove two screws holding the cord in place, unhook the old cord and install the new one the same way the old on was
Apr 14, 2014 | Riccar 8955 Upright Vacuum
The switch will not turn the vaccum off or on
The switch is activated by the lever you push in the handle. Start by tightening the screw holding the handle in. If that doesn't solve it remove the bag door and the screws holding the cover above the bag to gain access to the switch compartment. If you can't figure it out in there take it to your Riccar dealer
Feb 17, 2014 | Riccar 8955 Upright Vacuum
Riccar 8955 power cord replacement
Remove the dust compartment door to gain access to the cover over the wiring and switch compartment. Remove three screws to gain access to be able to remove the old power cord and slide it through the hole in the back of the vacuum. Put new cord through the hole and wire back up as it was before.
Feb 14, 2014 | Riccar 8955 Upright Vacuum
Replacing off switch
Remove the screw holding the handle to the body of the vacuum. Remove the screws to separate the parts of the handle to gain access to the switch.
Feb 01, 2014 | Riccar 4812 Vacuum
Install foot pedal release on riccar 8800 series
It's not hard to do but is almost impossible to explain how to do it. If you can look at one already installed on the shaft holding the pedal you can see how it's done. Visit your local Riccar dealer.
Jan 12, 2014 | Riccar Handle Release Foot Pedal - 8000...
Riccar 8955 quick cord release
Visit your local Riccar retailer
Nov 19, 2013 | Riccar 8955 Upright Vacuum
The switch to my Riccar 1500p hose is broken for the 2nd time. I don't want to replace the entire hose again, where can i get the switch and leads?
Take the screws out to take the handle apart. Remove the switch and take it to your hardware or local vacuum to to get the correct replacement.
Apr 03, 2013 | Riccar 1500 Simplicity S24 And S20...
Faulty switch
Your 8650 is an old vacuum. The switch is in the part of the vacuum where the handle goes down into. When you push the lever on the handle it activates the switch. To get to the switch take off the dust cover, remove the three Screws on the small cover where the handle goes in to see the switch. On older Riccar vacuums like yours sometimes the screw holding the handle in is loose which can cause the switch to not Always engage properly. To test this turn the vacuum on and wiggle the handle. If the vacuum vacuum cuts out you may only need to tighten the handle screw.
Jan 31, 2013 | Riccar 8650/8625 s Vacuum
Vacuums Logo
42 people viewed this question
Top Riccar Vacuums Experts
Chris Nomland
Chris Nomland
rebecca curry
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
