Freezers Logo
Ryan Okenfuss Posted on Nov 03, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Kenmore 5 cubic foot upright freezer. The lid gasket needs to be replaced. I have found the part number, it is 501114550006. Two different websites state that it is no longer available.
Chris Huff
Level 3:
Top Expert:
  • Kenmore Master 6,289 Answers
  • Posted on Nov 03, 2018
Chris Huff
Kenmore Master
Level 3:
Top Expert:
Answers
6289
Questions
Helped
2019626
Points
74913
5 Related Answers
Anonymous
  • 161 Answers
  • Posted on Jun 30, 2008
SOURCE: Old Kenmore Freezer
It is uaually coded into the model #. Usually in the middle. I can usually eyeball them. another solution is measure the outside dimensions of a refrigerator or freezer you know the size of then compare them. This will give you a rough estimate.
Curt Downs
  • 1779 Answers
  • Posted on Aug 08, 2008
SOURCE: door gasket for Kenmore upright freezer model 2539239712
Go to sears parts direct website. It's part #3206261 and is in stock, $93.07. Good Luck! countrycurt0
okcfirewall
okcfirewall
  • 80 Answers
  • Posted on Jul 20, 2009
SOURCE: I have 15 year old Kenmore upright freezer -- NOT
depends on what condition it is in in most cases yes as long as the doors and body are in good shape meaning doors not loose and hanging or holes or dings in the body to allow air and moisture to get in
Anonymous
  • 113 Answers
  • Posted on Sep 22, 2010
SOURCE: Need Freezer gasket for 20
I would suggest you check with a local appliance parts warehouse. They will also have a service manual that you can purchase that will guide you.
mike cooper
  • 884 Answers
  • Posted on Apr 20, 2012
SOURCE: WHAT IS THE PROCESS IN REPLACING THE GASKET ON MY KENMORE UPRIGHT FREEZER
If it is a push fit gasket it simply pulls out and the new one pushes in to the groove. Warm in hot water before fitting to ease it in. If the seal is part of the door, you have to replace the door as a complete assembly. Rare models have doors that can be taken apart and reassembled with a new gasket fitted but i don't think Kenmore is one of those.
What is weight of kenmore freezer model 25320402002?
For 5-foot-tall units: A 32 refrigerator or freezer weighs about 150 pounds and takes up 38 cubic feet. A 32-inch refrigerator or freezer weighs about 200 pounds and takes up 44 cubic feet.
2answers
What is the cu ft for frigidaire upright freezer mfu21m3gw1
Thank you for your post, friend!
I see you would like to know the cubic footage of your Frigidaire freezer. Based off the model number you have provided it appears that you have a 21 cubic foot freezer. Hopefully this information is helpful. -Matt
Freezer does not freeze anymore
the freezer usually has the condensor coil sandwiched ilong the outer cabnet and in the back the lines come out in to the compressor compartment as a tech i have found the steel line rusts where the epoxy coating is no longer in tact so i would say you most likely have leaked out the refrigerant
Feb 10, 2013 • Freezers
2answers
Chest freezer ice is building up on the inside lid
These ideas ****. Question was, what causes ice to build up in the chest freezer.
2answers
Capacity of Kenmore Freezer Model 253
I would like to know the capacity of my freezer
Need Freezer gasket for 20 cubic foot freezer upright Model #WFF20Z
1helpful
Hot exerior walls in a brand new Kenmore 28042 upright freezer
There should not be a fire hazard but you should be concerned that the freezer could break down if it is not allowed to vent the heat it produces. The freezer is not intended nor designed to be enclosed The manual must indicate specifications for minimum clearances for rear, top and sides, and may even be indicated on the big yellow sticker on the inside of the door. The clearances must be respected or again, the unit will fail, and the warranty may be voided in such cases.
Door gasket for Kenmore upright freezer model 2539239712
Top Kenmore Freezers Experts
Jay Finke
Jay Finke
ZJ Limited
ZJ Limited
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
