Please help with with wiring diagram, so that it's easier to figure out from the main unit the power wires and speaker wires - thank you
If you're changing the head unit as well, there are harnesses available to install the radio, you'll use rca cables from the head unit, to the amps, then run the speaker wires from there. You may want to consider a separate amp for the subwoofer. I'd suggest looking at Crutchfield, they are a reputable company, that will show you everything you'll need for the install as well as good instructions for doing the project yourself.
This is not easy because of the new model car. There are no aftermarket diagrams.
If putting in an aftermarket radio get a wiring harness specifically for your car. Match colored wires from harness to radio.
SOURCE: Need help in wiring speakers to amp.
The right speaker will connect to the R+ and R- terminals and the left speaker will connect to the L+ and L- terminals. Only one speaker per connection. If both speakers are not exactly the same brand, part number,size, etc. then they may NOT sound the same. Be sure to watch the polarity of the speakers so they don't interfere with each other. I.E. speaker + to amp + etc. Good luck.
SOURCE: Wiring Diagram
First, try looking here: http://www.crutchfield.com/learningcenter/car/amplifiers_movie.html If that helps, be sure to leave feedback or I don't get paid. Look all over the cruchfield page and you can find guides for every type of installation.
SOURCE: speaker wiring diagram
Hey there retgrunt, the information is at this location to download. the actual number on the guide is not the model you indicate, but the setup I believe is the same. I hope this helps Good luck!http://www.usersmanualguide.com/panasonic/dvd_home_theater_sound_system/saht70
SOURCE: Wiring diagram for Alpine MRP-F300
From the Crutchfield site:
Owner's manual
You'll use fig.8 for the front speakers and fig.9 for the subs.
SOURCE: connect powered subwoofer
