Hi!
We can help. :)
Check out our testing video and see how to pinpoint and fix the problem.
https://www.generatorguru.com/help-me-fix-my-generator-repair-advice/
If you need more advice we can get you in contact with one of our Generator Engineers to guide you. We do not charge for this service and are happy to assist you throughout the repair.
https://www.generatorguru.com/need-help/
Kind regards
The Generator Guru Team
Specialist Portable Generator Engineers & Parts Worldwide
www.GeneratorGuru.com
There are two reasons why the generator does not generate electricity: the generator does not build pressure because the core of the rotor has too weak remanence or magnetic reversal; the generator rotor is not connected to the excitation current, the carbon brush is damaged or the excitation system is damaged.
SOURCE: Generator dose not produce power,just stop working.
Check the rectifier board installed under gen cover that powers the brushes. This board has a capacitor about 1 inch long and 3/4 inch dia. If the capacitor looks swollen or burned replace board or carefully remove cap and replace with similar. You can use a larger capacitor with same rating, just tie cap to rear cover. Also check the condition of the brushes. Parts are not too expensive. Check with jacksmallengines on the web for parts. enjoy
SOURCE: My generator starts but not give 220 volts power
Check the voltage regulator and any fuses or breakers.
SOURCE: gnerator not producing ac power
I recently had a similar problem during "Sandy". I forgot to turn off the hot tub before starting the generator and the house lightswhere barely lit, dim, and flickering under the load. I quickly shut itoff andthe hot tub, but not before frying half of my generator. It will only produce 110now, not the 220 usual adn I need to get it fixed. I imaging you may be experienceing the same thing if you can't reset it. My generator has two reset buttons right next to the outlets on the unit itself.
SOURCE: generator runs but produces no power
Check out this video. It will show you how to test the AVR and alternator.
http://generatorguru.com/help-me-fix-my-generator-repair-advice/
From
there it will be much simpler to fix as it will point you to the part
that is failing. Also you can call us if you need further advice. We are
always happy to help.
Generator Guru
please check how many output voltage either 0 or some volts are present
