I have an iPhone 8 already paired and it works fine, but I purchased the watch for when I forget to take the phone with me. Thanks in advance. David
Unfortunately you can't pair an apple watch with any Bluetooth device other than your iPhone because it is an accessory and even though you can take calls and send texts with your watch it's not compatible with any device other than an iPhone but you can still take calls and texts with your watch {as long as you have a cellular apple watch}
SOURCE: How can I pair the anycom ARIS-21 bluetooth with
Just push the button for a long time until the led is not flashing but the colors of the led are changing red and green. I connected it to my laptop and my phone too.
SOURCE: I purchased a new Iphone and my Jabra will not
To remove the list, press and hold the Answer/End button, Volume up button and FM button at the same time. A beep indicates the list was removed from the speakerphone memory. The next time
you power on, the speakerphone will go into pairing mode as the first time you powered your new Jabra CRUISER on.
Thank You
SOURCE: Bluetooth keeps aking for a pairing code. each 4
Did you try just pressing enter (no code)? If not, try "0000" I found something here: http://fordfcsd.wunderman.be/UK/Audio%20-%20Multimedia%20-%20Navigation/Bluetooth%20%26%20Voice%20control/bluetooth%20%26%20voice%20control%20%28cg3504en%29%2001-2006.pdf which indicates "0000" is the code, but enter should do it
Testimonial: "worked with an old module i have, but radio is stuck on mute wid dis one. when i insert my newer module,it dos not pair with the phones but BT show up"
SOURCE: Apple Iphone 4 pairing instructions and asking for
How to Pair (Connect) a Bluetooth Headset to Your Phone
So you've heard of this new thing called "bluetooth..." But what is it? ...And what does it do for me? It's wireless technology that can link your phone to a headset, computer, another phone, or in extreme cases, your car and home.
We'll just start with the basics and connect a headset to the phone
Instructions
Things You'll Need:
* A Bluetooth cellular phone
* A Bluetooth Headset
Blue tooth can simply be called "a generic wireless technology that can connect your phone, computer, headset, PDA, laptop, and any other enabled device to each other."
In essences, it was designed to be a universal wireless connector between devices.
Ok... Here we go.
Make sure that both your phone and new headset are charged up.
Since every brand of headset is different, please refer to the instructions for "Pairing", but I will tell you how the most common headsets pair.
By the way, "Pairing" just means "connecting". If you find it more simple, you can substitute the word.
On most headsets, from the Headset being off, hold down the answer/end button down until the indicator light(s) glow a solid color (usually blue). This may take up to 10 seconds. They might flash first, then after a couple more seconds, go solid on.
On your handset, find the bluetooth menu.
On most phones, go to the settings menu, then to "connections" and then "Bluetooth". You are looking for a link to "Add a new device".
On Motorola phones, it is in the "Handsfree" link. Select [look for new device] select this option, and hit "OK".
Nokia Phones: look for "search for new audio enhancements". Hit OK.
On Samsung phones: **Bluetooth menu might be under "tools"** Look for "Add new device". Hit OK.
The phone will search for a couple seconds. If your headset is in paring mode, it will show up on the phone either with the name of device or something like this [unknown headset] or [b2.c3.f4.56.a1] (called a MAC address).
Either way, select it, and hit OK.
The phone will now ask you for a "Pin" or "Passcode", which is a 4 digit number. Headsets will ALWAYS have 0000 (four zeros) as a pin or passcode. I have never encountered a headset with a different number as a passcode. I have been in wireless for 10 years, and still have not found a headset that has any different numbers.
Enter these four zeros and select "OK"
The headset and phone will connect to each other. The phone will display a message that will be something to the effect of:
"Connected to headset".
At this point, the phone MAY ask if you want to use the headset. This means all audio from phone calls would be routed to the headset rather than in to the phone's speaker or earpiece. Select yes, or ok.
Your headset is now set up for you to talk on like a REALLY important CIA agent or something of the like...
Keep in mind that when a call comes in, the phone will still ring like normal.
You can answer the call by either:
1. Pulling the phone out of your pocket and hitting the answer button.
2. Touching the answer/end button on your headset without reaching for you phone.
The range of your headset is up to 30 feet, in a direct line of sight.
If you go into another room, your range may be decreased.
If you do happen to go out of range, the call will be transferred back to the phone, and as soon as you are in range again, touch the answer button on the headset to let the phone know you're back in range. It will re-transfer the call back to the headset.
If you turn off the phone, or headset, you can repair them again simply by going to the bluetooth menu and selecting the headset again from the list. It will reconnect without a pass code and you are up and running again.
*** Please note that you do not have to hold down the answer/end button on the headset until it goes a solid on again.
Tips & Warnings
If you have difficulty, please feel free to contact me and I'll help you get things sorted out.
