The attached componants are a Yamaha CX A5100, two front polk audio A9's and a 5.1 Bose Acoustimass 10 Series V Home Theater Speaker System. The manufacturer has reset it before. (no parts needed to be replaced at all) How can i reset it myself?
SOURCE: yamaha v50 keyboard won't boot up
The 2013 button battery must be replaced to boot up. You should find or make a battery holder with two leads to replace the soldered in battery.
SOURCE: 8001 Receiver keeps going into protect mode. What
Fastest way to check the receiver is to disconnect all speaker wires at the receiver and turn the unit back on. If it does not go into protect, your receiver is ok and you need to check all wires and speakers. If just one piece of braid on a speaker wire touches the other, it may not shut off immediately, however, as you turn up the volume the current level rises in the wire and creates a short. Thus, shuts down the receiver. If you need further help troubleshooting, post a comment and I can walk you thru it. Hope this helps.
