SOURCE: John Deere Gator 4x2 - Left Wheel doesn't move when in 2nd gear
I would replace the high/low switch and the reverse switch. One time a replaced the high/low switch and the reverse switch quit on me 2 weeks later.
You can also get the Peg Perego Gator Shifter that upgrades the vehicle.
You can get the parts and repair help at this site
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego-switches-and-shifters.html
They have helped me several times.
Hope this helps
SOURCE: battery is charged but car is still not working,
I have the switch go bad on the gas pedal. You can find a replacement here http://tigerimports.net/sunshop/
SOURCE: my gator 4x2 makes a loud rubbing sound when i hit the brakes
there are no brakes on the kids toy
SOURCE: need to change motors on pegperego4x2 johndeere gator
1. Remove the center caps from the rear wheels
2. use a 13mm wrench on each side and loosen the bolts
3. remove the rear wheels and axle
4. remove the red pin at the front of the dump bed
5. remove the two black pins at the rear of the dump bed
6. remove the dump bed
7. lift the green plastic cover off
8. remove the two screws that hold the gearbox and motor to the body
9. remove the gearbox and motor assembly
10. remove the two screws that hold the motor to the gearbox
