You didnt indicate whether the switch was defective or not. From looking at the image, it appears that the identified conductor (white) was cut. Have you tried to reconnect the wire (white to white) and see if the heater is working?
You can buy replacement parts from here:
https://pantherrvproducts.com/search.php?search_query=Atwood%20water%20heater%20switch%20§ion=product
https://pantherrvproducts.com/search.php...
SOURCE: I replaced a GC6AA-9E with a GC6AA-10E, question
Yes. If your using it in an RV, your converter can supply the needed 12 volts, if it's not already there.
SOURCE: i have a atwood hot water heater GC6AA-10E its o...
Does yours have the little cut-out diode looking thing in the plastic jacket installed between power wire and thermostat? If yes, remove it from the circuit and connect female spade of wire, to male spade of thermostat,(just removing it to by-pass it) and try it now. Let me know what happens.
SOURCE: Atwood GC6AA-9E water heater isnt working properly
The ignitor is also a flame sensor. If it's not working to ignite, good chance it's not sensing flame to keep gas flowing as well. Could also be board.
SOURCE: have a atwood GC6AA-10E water
If you've been using it in past on hydro then it should be on, unless someone had a reason to shut it off, like winterizing or something. You normally find it on the side of that cover, but may be on top. Hard to see it usually to confirm it's on, so I grab a small mirror and flashlight . Are you familiar with a multimeter and do you have one or access to one?
SOURCE: I have an Atwood model GC6AA-10E and the water is
Your 2 separate thermostats are pre-set so adjustment isn't possible although you can purchase a hotter thermostat. Normally the complaints I get are that propane is not hot enough, but electric is too hot, so I'm wondering if perhaps you haven't got a valve at by-pass in wrong position, or defective that may be allowing cold to mix with the hot. Make sure any valve in between hot (top line) and cold line (bottom) are all the way in off position. You want flow in to bottom open, and out the top open, and anything else in between, shut off. Have you actually tested a cup of hot water from tap to see what temperature it is? I just don't see both thermostats as being faulty at same time, but?
Where does the green wire or the copper wires connect? Do they connect to each other?
What would really help is to know where each wire goes
Black to black, white to white, green to bare (the grounding conductor in the non-metallic sheathed cable is the bare ((or non- current carrying)) conductor).
Thank you very much
White needs to be reconnected to the other white. The switch cuts the hot (ungrounded) conductor.
(As best i can tell. The black wires ard still intact, and the green is still connected to the bare).
