SOURCE: drain hose leak kenmore stackable wash and dryer
It appears your drain hose has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
SOURCE: Frigidaire stackable front load washing machine
ok we have to take bottom front panel off,,theres three torex head screws..now straght in front of you is the pump ,,remove the filter turn it counterclockwise,,theres always a little water in it so be prepared...remove clogg and we should be good all coins are mine,,onthejob
SOURCE: LG front load washing machine - need to replace drain hose
It's jusy one clip go in from the bottom
SOURCE: replace drain hose on mod LW6501W2 washing machine
Enter model # at www.appliancehelponline.com for diagrams and illustrations.
SOURCE: my frigidaire stackable washer/dryer will not drain water or do anything past filling up
my washer fills up with water but will not drain
Hi friend, I appreciate your post!
I see that your Frigidaire washer is not spinning. I would check to make sure that the drain hose is not restricted or too long, because that could cause your appliance to not spin. It could additionally be a possible issue with the drain pump or timer inside your appliance. I would set your appliance to spin and if you hear a humming noise the best step would be to contact a professional to come out to your appliance and diagnose it properly. Hopefully this is helpful. -Matt
