SOURCE: Hotpoint FFA70S fridge drain blocked
PEACE,
ngfam1 at your service,
Do not use sink chemicals!!!!!!!!!!!!!!
In the hard ware stores or home depot they have small short,
snakes that are flexible and thin that can go in the hole to clear it!
Tell the home depot guy to help you find what I'm
telling you to buy!Print this out and show him what I spoke of!
Bless you,
Please give me a good rating before you signe off
SOURCE: Hotpoint fridge freezer RFA 06. Freezer OK, but Fridge not working after drain unblocked.
fault is nothing to with unblocking drain hole
SOURCE: F&P Active Smart E521TRE Removing freezer back panel
My fridge (E440T but I believe the E522B is similar) had a broken fan wire and i had to pull off the rear panel and re-solder a wire. I created a document for others to follow that shows the rear panel removal if interested at http://www.accentis.com.au/downloads/misc/How I fixed my Fisher and Paykel Fridge Active Smart Fridge.pdf
Thanks to all postings on this site - it really helped a lot.
SOURCE: Blocked drain pipe from freezer
you need to defrost the unit for 48 hours with both doors open, then try using some curtain wire up the drain and see what comes out.
cheers
SOURCE: E521T fisher & paykels fridge is freezing everything
trn your thermostat right down see if that helps
