Question about Mustek Audio Players & Recorders
My mustek pvr h140 locked up, screen said conect to pc which i did now device will only charge not boot up or turn on [no blue light],
Have no soft ware cd only player.
SOURCE:
SOURCE: my mustek pvr-H140 freezing
Tje pvr-h140 basicall have 3 major components
1- 40 gb hard disk
2- battery pack similiar to the cordless phone battery packs
3- integrated panel with LCD and control buttons; usb port; power port; av in/out port.
when the unit hangs on initialize; this mean the hard disk is not responding. you can hit the recessed reset button and and power it back on. if the hard disk is OK this should clear up the issue.
if the hard disk is bad (crashed) then you need to replace the disk. Usually a fitjitsu 40GB notebook drive
also if the unit was dropped; constantly banged; etc then the cable to the hard disk to the integrated panel may be loose. The disk to cable is pinned and doesn't come loose but the other end of the cable is taped to the integrated panel and can come loose if the unit is not handled properly.
finally if the boot up files are corrupt; then you should be able to see it on the pc with the usb connection.
In this case you need to download and restore the files as discussed in the other solutions. Basically mustek has a website with all the drivers.
Posted on Dec 12, 2008
  • 22 Answers
SOURCE: NEED DRIVERS FOR MUSTEK PVR-H140
HI,
the drivers for the unit are available at http://www.nodevice.com/driver/_PVR-H140/get33981.html
you can use the unit as an external drive, you will need to connect the it to your computer via usb then power it up, after 30 seconds or so it should show up on "My Computer" as an extra drive.
if it doesn't show then the internal battery could be flat, though it will charge via the usb if the power is off (red light on when charging) or use the supplied power adapter.
G.
Posted on Jan 14, 2009
  • 4 Answers
SOURCE: HOW TO CHANGE THE MUSTEK PVR-H140 BETTERY
It is real easy to change the battery, I have done mine a few months ago
if you remove the screws from the back top and bottom (4) and remove the case
next remove the 2 small rubber strips from each side of the hard drive, then very carefully pull the connecting ribbon off the hard drive, this can be tight so gently prise apart with a screw driver,
once the hard drive is removed you will see some earthing straps just make a note of where these are located as you will need to put them back in the right place, they simply touch the hard drive,
now you shoud see the battery (very thin in a blue plastic case) you might want to remove the rubber proctective stuff just to make it a bit easier there is a simple pull/push connector
just unplug it and replace with new battery and reverse the procedure.
Dont panic if the unit fails to switch back on as mine did when i re assembled it
it was just one of those earth straps in the wrong place.
I hope this helps,
P.S I changed the battery on a unit I bought on ebay and i had nothing to loose
if you are unsure do not attemp the repair.
Posted on Jan 17, 2009
  • 4 Answers
SOURCE: just bought the mustek pvr-h140 without manual. No instructions!
I have the instructions on pdf if you can send me an email address i will forward on
Kind regards
Kev
SOURCE: MUSTEK PVR-H140 died on me
You may already know this, but tap the power button once more and it may turn on the screen.
Posted on Feb 26, 2009
Jan 31, 2009 | Mustek PVR-H140 Digital Media Player
Mustek PVR-H140 shuts down when I insert some SD cards
Yes that's correct newer SD Cards use faster memory chips that are not always compatable, not just with this unit but you can have the same problem with cameras and other MP3 players as well.
The PVR-H140 is quite old now so stick to the older type cards, oh and they dont like being hot swapped, this can cause a shutdown or driver corruption, insert them before turning the unit on.
Jul 26, 2008 | Mustek PVR-H140 Digital Media Player
HI,
G.
Jul 12, 2008 | Mustek PVR-H140 Digital Media Player
My mustek pvr-H140 freezing
1- 40 gb hard disk
Jun 18, 2008 | Mustek PVR-H140 Digital Media Player
Frozen in "Initalize"
you need to go to musteks website and download the following file pvr-h140_restore_files.zip from product support area
that should get your pvr working again ?.
link to support page
http://www.mustek.com/mustek/supportdrivers.php
Apr 08, 2008 | Mustek PVR-H140 Digital Media Player
Mustek pvr h140
yeah, man, i did the same. cracked the glass, without damage to the screen, and then just made one myself, cutting it out from a cd-box and then glued it on :)
Feb 18, 2008 | Mustek PVR-H140 Digital Media Player
Mustek pvr-h140
Are you trying to restore the files you previously had on your Mustek or just trying to get it to work as it did before the format? If you're just trying to get it to load, follow these instructions:
"Install the PVR Console software in the bundled CD and connect the device to PC. The software will help to restore system data and boot up files to the device automatically. When the copying is done, restart the device for twice."
If you're trying to restore the data you accidentally formatted, connect it to your PC and try using a program such as Free Undelete to restore the files that were previously deleted. In the program, you need to browse to the drive that your Mustek shows up as on your PC (so if the drive is X: you need to restore files on X in the program).
Jan 09, 2008 | Mustek PVR-H140 Digital Media Player
PVR-H140 doesn't work but cannot restore files
Problem is once the hard drive is corrupted you can't access usb to fix the problem. You have to remove the four screws on the back cover remove the 40gig hard drive. Find a laptop or an ide to usb adapter to reformat the drive. Must be fat32 not ntsf. Then copy all files back onto drive.
Nov 10, 2007 | Mustek PVR-H140 Digital Media Player
35 people viewed this question
Top Mustek Audio Players & Recorders Experts
John Elliott
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Mustek Audio Player and Recorder Expert? Answer questions, earn points and help others
