SOURCE: outdoor shots are blue
Hey VickylnStL,
What I believe is going on is your white balance setting has been set to incandescent light which on your camera is a light bulb. For outdoor shots you should have the camera set to auto white balance, or have the white balance symbol set to the sun icon or the cloud icon depending on the conditions outside. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
SOURCE: Canon G6 images have pink outline
A pink hue on pictures usually points to a CCD failure.
Official service manual for the Camera:
http://www.tradebit.com/filedetail.php/4593815-canon-powershot-g6-digital-camera-service-manual
SOURCE: Flash doesn't work
If there is a red blinking flash constantly blinking on the LCD screen of the camera this indicates a failure with the flash charging sensor in the camera. It has failed and needs to be replaced.
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $76 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
SOURCE: Airforce 12000BTU Air Conditioner wiring problem
The outdoor unit should have 2 small wires connected to the contactor coil. This delivers the 24v "Signal" to energize the coil. The wire from the t'stat for cooling are usually yellow, in almost every case. When you put the t'stat in the cooling mode and set the temp lower than the room temp, the indoor and outdoor unit should come on. Check for voltage on the terminal block for 24 volts accross the yellow and common wire. Common could be ground on some handlers. If you have the 24 volts, then check for 24v on the 2 small wires (usually 18 to 22 gage wire) on the contactor coil. If no voltage, trace the 2 wires back to the indoor unit and see where they go. If they are the ones that are not attached, put one on the yellow wire terminal and the other on the common terminal. This will send power to the indoor unit and then piggyback to the outdoor unit. Do not remove the yellow and common from the terminal block. Don't be too concerned about the colors from the outdoor coil wires. Just make sure they are hooked up right. Good Luck and hope this gets it going.
SOURCE: I have a 900 MHz Wireless Indoor/Outdoor Mono(Accurian)
yep the power to it is in question and since it is a 9 volt adaptor as mentioned that will need to be checked 9vdc adaptors are over the counter items in most radio shops
