Hello Kevin, sent you the link of the user manual of the Pioneer VSX4800, there on page 22 tells you the steps for the tuning of stations and how to save them in the memories
Greetings Franco Dosil
Hola Kevin, te env?o el link del manual de usuario del Pioneer VSX4800, ahi en la pagina 22 te indica los pasos para la sintonizacion de emisoras y como guardarlas en las memorias
Saludos Franco Dosil
https://www.hifiengine.com/hfe_downloads/index.php?pioneer/pioneer_vsx-51_4800_4900s_4950s_en.pdf
SOURCE: Remote code for Pioneer VSX-50 A/V receiver.
Here are the codes for your receiver:
Pioneer 31023, 30014, 30244, 30150, 30630, 30080,
30531, 31384
Here is a link to your manual:
http://www.directtv-advisor.com/support-...
SOURCE: Bose 901 connection to Pioneer VSX-917v Receiver
any pre-out should work. i believe the bose have a rca jack connector for attaching to the receiver. look at the new receiver connection diagram. any output that is rca designed for use by a recording device will send a signal that the 901's can see.
always check the manual on both before connecting for any precautions.
good luck
mark
SOURCE: Pioneer Home Theater System VSX-305 owners manual
Click HERE to download Pioneer VSX-305 service and instruction manual. Last portion of this manual has instructions and first part has all technical details and schematics.
If above said link does not work, Click HERE and register yourself with any email address and then proceed to download on above said website.
Hit "add a comment" button for further query/ info.
Thanks.
SOURCE: Pioneer VSX-D411 receiver "Amp Error" message
Unfortunatelly your receiver has failed. The front panel is telling you one of the power modules is probably bad. Not an DIY type of repair. These parts are near $40.00, plus cost of replacing.
Look at options to replace your trusted receiver with a new one.
Good luck
SOURCE: I can't preset radio stations
this is how i preset my stations, im not sure if you have done this before.
fm can save 20 stations and am can save 12
1] chose your desired station
2] press & hold the play/memory button until P01 pops up and flashes
3] to save the station, press & hold the play/memory button
if you'd like to save another station, then repeat steps 1 & 2,
then press the play/memory button again until P02 pops up,
repeat step 3.
to listen to your preset station, all you have to do is press the play/memory button.
hope this helps
