SOURCE: HP OJ 5610 Drivers-? Can not install printer.
In this case, there's no mystery as to the cause of the problem. You will be unable to use this printer with your operating system because there are no existing print drivers that work with 64 bit Vista. Your printer will work with Windows 98, Windows 2000, and Windows XP, but not with Vista at all.
You have only two options...use a different HP printer that will work with Vista, or get a PC that has one of the supported operating systems on it and connect your current printer to that PC.
Sorry. I know this isn't the answer you were looking for, but that's the best I can do until the proper drivers become available.
SOURCE: autocad 2006 on Vista home premiun 64bit
This will not work on vista 64 BIT you will need autocad 2009 64 bit version.
SOURCE: XP Windows not recognizing Sony 800x camera
Install the Driver Again
http://www.sony.co.in/support/download/140059/product/dcr-hc28e/modelfirst
Enjoy
rajkumar
SOURCE: Cannot install HP Deskjet 3745
Open the Devices and Printers folder
Right click on the Printer icon and Click on Troubleshoot
Follow the instructions and finish the Troubleshooter Wizard
You should be able to print
The USB streaming driver for the Camcorder is not available
for Windows 7 OS from Sony at this point. Hence it is not possible to transfer
videos using USB interface. You may use i.LINK or A/V interface to transfer
videos from the Camcorder to the Computer which is running on Windows 7
Operating System.
Please
follow the steps to transfer video to a computer using an i.LINK connection
(IEEE 1394).
IMPORTANT: Video capture software and a compatible video capture card must
be installed on the computer. Depending on the computer manufacturer, various
video capture cards and software (Adobe Premiere, Roxio Video Wave, Microsoft
Windows Movie Maker, etc.) may be available or already installed on your
computer. If necessary, contact the manufacturer of your computer for further
information.
NOTE: Many Sony VAIO computers are bundled with Sony DVgate Motion or DVgate
Plus software for video capturing. Some VAIO computers also include Click To
DVD software that will allow video capture to the computer hard drive or
directly to a DVD.
i.LINK
Cable.
i.LINK
port.
NOTE: The computer i.LINK ports and capture cards
may have either 4-pin or 6-pin connections. Sony digital camcorders use i.LINK
ports with 4 pins. If your computer only has a 6-pin i.LINK port, then it will
be necessary to use a 4-pin to 6-pin i.LINK cable.
It should now be possible to copy the video using
the video capture software if the computer hardware and software are configured
correctly.
for Windows Vista OS from Sony at this point. Hence it is not possible to transfer
videos from the Camcorder to the Computer which is running on Windows Vista Operating System.
Please
(IEEE 1394).
information.
directly to a DVD.
i.LINK
Cable.
i.LINK
port.
correctly.
Operating System.
Please
(IEEE 1394).
information.
directly to a DVD.
correctly.
i.LINK Cable.
i.LINK port.
Operating System.
Please
(IEEE 1394).
information.
directly to a DVD.
i.LINK
Cable.
i.LINK
port.
correctly.
Thanks for understanding. Please let me know if you require any clarifications.
Camcorder is not available from Sony at this point. Hence it is not possible to
transfer videos using USB interface. You may use i.LINK or A/V interface to
transfer videos from the Camcorder to the Computer which is running on Windows 7 Operating System.
Please follow the steps to transfer video to a computer
using an i.LINK connection (IEEE 1394).
information.
directly to a DVD.
i.LINK
Cable.
i.LINK
port.
correctly.
Operating System.
Please
(IEEE 1394).
information.
directly to a DVD.
i.LINK
Cable.
i.LINK
port.
correctly.
