I used the tv for a few years as a monitor and even after unhooking all cables and plugging in outlet i still have the flickering bands
SOURCE: geforce 5500 fx for agp ultra screen flickers
use the build in video card to install the AGP card drivers first and install the card and go into the bios and make sure its set to boot from the agp slot first not build in . Thanks
SOURCE: dark band 6 inches wide middle of the screen
YOU MAY HAVE A DEFECTIVE Y DRIVER BOARD OR A RIBBON CABLE THAT HAS COME DISCONNECTED. THIS NOT USUALLY THE PANEL SINCE THE PANEL DOES TURN ON. TAKE IT TO AN AUTHORIZED SERVICER.
SOURCE: I have a 2inch wide band down middle of screen on
1) Have you installed new drivers or software or drivers? If so, remove them and restart the computer.
2) Try applying pressure with your fingers on top of the screen. If the band dissapears or dimishes, you may have a broken screen and it will need to be replaced.
SOURCE: Hisense tv turns on and off
STOP!
The unit has a fault on its power board and sustain board.
It turns off because the sensor is preventing some component from bacoming overheated and catching fire or damaging further components. Seel professional repair.
Please rate my help++++Thanks for using FIXYA
