Question about GE Monogram ZDI15C Automatic Icemaker
I need a water valve for a Monogram zd115 Ice maker. Where should I buy one. and what about a part number??
  • Anonymous Mar 12, 2014
    dc33 I want to buy the inside parts to the inlet water valve with buying the whole valve but can't find the parts .Help
    President:
  • 1,273 Answers
If you have the model number of the machine, or the old part in hand, you should be able to get your part at any appliance parts supply house (look in the yellow pages). It is better IMHO to take the part with you to the store.
Best regards, --W/D-- please feel free to rate this solution - thanx!
Posted on Aug 04, 2009
SOURCE:
Water keeps running and the ice maker isn't making ice
The ice maker will not make ice with the water running in contently this keeps the water temp to high. Turn machine off, cut water supply off to machine, remove water inlet valve, ether take valve apart and rebuild it or replace the water inlet valve. Reassemble in reverse order and machine should make ice.
Jun 29, 2014 | GE Monogram ZDI15C Automatic Icemaker
Hello. My G.E. Monogram water dispenser trickles water after we get water from it. We have to keep a cup there to catch the excess water. How do I fix it so it stops as soon as we get water out of t
Try replacing the Water Valve. It is located in the back of the refrigerater, left side. You should see three tubes connected to it. This part fixes the following symptoms - Leaking water, Water dispenser will not dispense water, Ice maker will not make ice and Ice maker won't dispense ice. GE part#WR57X10032. The Water Valve is extreemly easy to replace. Only takes about 15 mins total time to remove, install and confirm. I just replaced mines..my problem went from leaking water to no water was dispensing at all. I have the GE Profile, it uses the same water valve as your GE Monogram. There is a You Tub video that also shows how to replace. Good Luck!
Dec 27, 2013 | GE Monogram ZISS480DRSS Stainless Steel
Zd115
Part number AP3865361 whirlpool same as ge
Jun 24, 2013 | GE Monogram ZDI15C Automatic Icemaker
Our automatic ice maker will not quit dripping in the freezer. It keeps clogging the ice maker with icicles and large blocks of ice. Essentially, it keeps "freezing over." We have defrosted it...
if it keeps filling and overflowing you have a bad water valve on the back of the fridge.the part number is WR57X10027 and the valve is around 75 dollars.first thing lift the arm or shut off the ice maker so it won't leak anymore,you're missing a few letters off of the model number so when you call your parts store give them the full model number,open the fridge door,look up on the right hand side wall up near the ceiling and give them the model number to make sure you get the correct valve,shut off the water supply to the fridge,then have the new valve next to the old valve when you remove a water line from the old valve just connect it to the new valve,do this until everything is changed out and the new valve is in place,turn on the water supply and you can check the ice maker to make sure it doesn't overflow.you can manually start the ice maker by grabbing the plastic arms of the ice maker and pull them forwards slowly until the arms start to advance on their own,you'll hear the water valve fill the ice maker and then you can watch it fill to see if the water is filling it correctly and i'm sure you'll be fine with the new water valve installed
Jun 05, 2011 | GE Monogram ZDI15C Automatic Icemaker
Water overflowing in ice maker tray on a GE
make sure your refrigerator unit is level first . If it is , and you have eight square faced plastic cover on the front of the ice maker itself that can be removed by un- snapping it, remove it and see if there is a small screw with a spring underneath it or positive or negative arrow's on the unit where the screw is located. Regardless, if there is a screw all by itself turned the screw 1/2 turn Counterclockwise. this will decrease the amount of time the water valve is open during the ice bin filling cycle.
Mar 13, 2010 | GE Monogram® ZISS420DMSS Side by Side...
Ge monogram fridge over freezer model has stopped making ice
water valve dripping like a faucet and making a big old ice cube in the fill tube? Ice cube hung in the ice maker? bad water filter? A wittle bit of all of the above?
MONOGRAM MANUAL
IM6 notes
Bonus
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 12, 2010 | GE Refrigerators
I tested the ice maker by pouring water in it and it made ice could the selinoid be frozzen and how can I fix it
Sounds like if you put water in ice maker and it dropped ice but won't make ice on it's own then the water valve or water filter is bad. Replace filter, purge air, then check a day or two later to see if it is making ice, if not then replace water valve on back of unit where water line ties in at.
Sep 30, 2009 | GE Monogram ZDI15C Automatic Icemaker
Ge refrige freezer ,water to ice maker.
HI.YOU NEED TO CHECK THAT THE WATER VALVE IS WORKING OK THERE ARE TWO SEPARATE VALVES FOR THE FRIDGE
GOOD LUCK MOHAMED
PLEASE RATE THIS
Oct 19, 2008 | GE Monogram ZDI15C Automatic Icemaker
GE Monogram ZDI15C Automatic Icemaker Logo
190 people viewed this question
Top GE Kitchen Appliances - Others Experts
John Tripp
John Tripp
geapptech
Audie Bogus
Audie Bogus
Are you a GE Kitchen Appliances - Other Expert? Answer questions, earn points and help others
