Clever choice monitor SDI-1986a
Go to the manufacturer's website and look for a downloadable manual for the unit that you have. Most are posted where you can get them and print one out.
Hello, I do not what device you need to set, but I found for you just an example.
Apparently there is a Set and M button in it to do so.
You may be able to contact by phone or email one of the online vendors of this monitor to request a copy of the instructions. (You may have to offer to pay for a copy if they insist.)
Example:
https://www.diabeticcorner.com/clever-choice-fully-auto-arm-bp-monitor-sdi-1986a/
SOURCE: blood pressure monitor problem
The two numbers that measure your blood pressure are written like a fraction: one number on top and one on the bottom. The top number in a blood pressure reading refers to the systolic pressure. It measures the pressure inside your blood vessels at the moment your heart beats. The bottom number represents your diastolic pressure. It measures the pressure in your blood vessels when your heart is resting between heartbeats. A good blood pressure for most people will be under 120/80, as most people with blood pressure problems have high blood pressure. However, extreme low blood pressure can also be a serious health concern.
SOURCE: Mabis Wrist Talking Blood Pressure Monitor set to Span. Need Eng
this website is the main website for MABIS to download their product manuals that can help you with your problem with your blood pressure monitor. Hope you can find your instruction book on this website. Good Luck and God Bless!!
http://www.mabisdmi.com/downloadsupport/default.aspx
SOURCE: Setting Date & Time
With the power off press "Digit". Month is blinking press "Set" for correct month. Next press of "Digit" will give you Day, Hour, and then Minutes.
SOURCE: How do I change the time & date on Lumiscope
My husband found the manual elsewhere on the web at http://www.manualsonline.com/
SOURCE: I NEED THE MANUAL OR INSTRUCTIONS FOR THE CVS BLOOD PRESSURE
Press Set Time/.Date button and hold down for several seconds. When you let go number - year - will start flashing. Use MEMORY button slowly to correct year. Push Set Time/Date button to set year. Next number will be month - same process. Then date - same process. Then time beginning at midnight using 12 hour clock - same process.
