If diy. turn off power, remove plug from socket.
remove access plate or back where cable enters
and observe internals . Ascertain if there is are fuses were cable attaches. if nine leave and contact electrical repairs or supplier. remember if you remove or undue screws, you void any guarantee remaining.
SOURCE: Newhome electric cooker = problems with oven
problem is 99% sure is the cvircular element round the fan. easy to replace
SOURCE: Roper gas range and oven with electric igniter
First look to see if the ignitor is coming on. Most common problem is the ignitor is weak or just bad. When the power is applied to the ignitor it glows and builds up resistance to open the gas valve then it lights. If the ignitor is weak or bad it will not build up enough resistance for gas to come into the burner. One sign of this would be a "woosh" sound when it trys to light. If the ignitor is coming on but not lighting it is most likely the ignitor is bad. Should have a full glow. Also, if the ignitor looks whiteish in color this is a sign of it going bad. You can compare to the broil ignitor to be sure. If the ignitor doesn't come on at all will need to see if you have power to the ignitor. Let me know what you find and let's solve it before you rate the solution.
SOURCE: User Manual for Belling Electric Cooker
The clock is flashing zeros because you need to set the clock timer.To do this you need to press and hold in both of the the cook period and end time buttons together, then with both buttons still held in , press either the "+" or "-" buttons to set the correct time of day
SOURCE: location of thermal fuse in leisure cookmaster
where is the thermal fuse located in a leisure cooker
