SOURCE: lid of Russell Hobbs pressure cooker is broken
Try going to MarBeck.com they are a great source for small appliace parts.
http://www.marbeck.com
SOURCE: Steam coming out of floating valve on handle.
No. if the steam is coming out, the vent valve is not seated on the vent and pressure won't build up. Either remove the plastic cover from the vent valve or slide it up enough so that the valve seals on the vent. If you remove the plastic cap, you will need to manually tilt the valve to "quick-vent" the cooker. Watch out for steam burns! Should work fine after that. You need to unplug the cooker and re-plug it to reset the "E4" error message.
SOURCE: Looking for place to order replacement Seal Ring
Replacement parts for the Wolfgang Puck pressure cookers are available here:
http://www.wpcookware.com/categories.asp?cat=29
If you do not see the part you require or are unsure about the model number; suggest you contact their Customer Service at 1-800-275-8273 or via their webform at:
http://www.wpcookware.com/contact.asp
Sorry someone has not responded sonner.
SOURCE: Pedrini Pressure cooker instruction book and valve
they can set you up with what you need herehttp://www.epinions.com/t-safety-valve-for-pedrini-pressure-cooker?sb=1
SOURCE: Manual for Sunbeam Vegas Electric Pressure Cooker VEP 600
call or e-mail the manufactor or write them they might have it.
