SOURCE: kenmore washer shakes violently during spin cycle
syrny,
Not sure what you did, exactly. First, does the machine shake when spun empty...and then with water only? If so, you have probably failed to tighten something or misaligned something. Go over your work.
No shakes? Rearrange your load. You may have a pair of heavy wet jeans which is throwing the whole thing out of kilter. It only takes about a half pound of sodden clothing to do this.
SOURCE: Kenmore 22932 Top load washer has excessive vibration at end of spin cycle
IF THE FLOOR IS NOT ABSOLUTELY STABLE, IT WILL MAGNIFY A SMALL VIBRATION INTO A LARGE ONE. PUT SOMETHING ON THE DRYER IF IT SETS NEXT TO THE WASHER, AND TURN ON THE WASHER INTO SPIN. IF THE ITEM ON THE DRYER SHAKES, THE FLOOR IS MOVING.
IF THE WASHER IS ON CARPET, REMOVE THE CARPET OR CUT HOLES IN IT WHERE THE FEET ARE SO IT IS NOT SETTING ON THE CARPET. THE CARPET AND PAD WILL BE TOO SOFT FOR THE WASHER TO SET STABLE.
ALSO, PICK UP ON THE REAR OF THE WASHER TO RESET THE AUTO LEVELING REAR LEGS. YOU SHOULD HEAR THEM MOVE AND RESET WHEN YOU SET THE WASHER BACK DOWN.
SOURCE: G E front load washer shakes like crazy in spin
Removed the plastic shipping plugs in rear of machine
SOURCE: My Kitchen Aid drum is
this sounds very much like the bearings have badly worn,rite pain to replace.
Hey friend, thanks for your post!
It sounds like a possible issue within the drum of your Electrolux washer and that is why it is jumping around and making a noise. Is this a new installation? If so, I would suggest checking the back of your washer to assure the shipping bolts have been removed.
If it is not a new installation it could be a potential issue with your shocks or drum and I would suggest seeking additional assistance from a professional for further help. I hope this information is helpful. -Matt
