Sandra Mcmaster Posted on Oct 31, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is there a manual available for Pioneer Au/Vid Receiver VSX-1018AH ?
Have been given A Receiver witn no instruction book or chords to set up speakers
Argospete
Level 3:
Genius:
  • Master 1,035 Answers
  • Posted on Oct 31, 2018
Argospete
Master
Level 3:
Genius:
Answers
1035
Questions
Helped
223365
Points
2731
Search box. and enter your question might be happily surprised
5 Related Answers
Anonymous
  • Posted on Jun 24, 2008
SOURCE: Pioneer VSX-505S Subwoofer Installation
That type of subwoofer is not used with this receiver. This receiver actually outputs no power for a subwoofer, therefore only needs a plain ol' rca signal wire. This is due to the fact that you need a powered sub... one that you plug in to the wall and it has its own built in amp. you simply run an rca from yyour 505s to that sub.
Anonymous
  • 4 Answers
  • Posted on Feb 07, 2009
SOURCE: Owner's Manual - Pioneer VSX 455 Receiver
It should be compatible with all of them. I have one that works just fine with my Sony HD/TV, HD DVD PLAYER, etc. The only difference is that its is stereo w/ a middle speaker hook up, if you so desire.
I find it just as enjoyable and easy to use as my Denon 6.1 with fewer speakers. That is because as men, our hearing range is poorer especially as we grow older.
Email me with any other concerns you may have.
Thanks,
dthomas
Chicago, IL
[email protected]
Anonymous
  • Posted on Feb 18, 2009
SOURCE: Pioneer VSX-D608 Optical connection
The manual states that the default association of each digital input in as follows:
  • Optical 1: CD
  • Optical 2: MD
  • Optical 3: TV
  • Coax: DVD
Use the "Signal select" button to set the receiver to use a digital input, and the Dolby/DTS button (above "Signal select") to enable decoding.
As samz11 stated above, a remote is required to alter the digital input mapping.
Anonymous
  • 10594 Answers
  • Posted on Apr 16, 2009
SOURCE: Pioneer Home Theater System VSX-305 owners manual
Click HERE to download Pioneer VSX-305 service and instruction manual. Last portion of this manual has instructions and first part has all technical details and schematics.
If above said link does not work, Click HERE and register yourself with any email address and then proceed to download on above said website.
Hit "add a comment" button for further query/ info.
Thanks.
Anonymous
  • Posted on May 16, 2009
SOURCE: PIONEER VSX-D411 RECEIVER
Here's a link to the owners manual:
http://www.manualnguide.com/manual-get/6009/
I want the speaking voice to be loader than the background voice
I think you mean you want to alter the balance between the center speaker and the others.
Assuming you've performed the initial speaker level adjustments according to the manual (available at retrevo.com), it is also possible, via the remote, to alter any channel level while listening to a program. See the Tip on page 49.
VSX-1018AH-K 7 Channels Receiver: My VSX 1018AH mutes automatically after 15 seconds...
The exact problem just started with my same receiver, did you get a solution to it in any way ?
Have a Pioneer VSX-1018 receiver. When I connect
You speakers are out of phase. Check to see if the polarity is correct on the receiver and the speaker. Positive (red) with positive, negative with negative (black). Also check the impedance of the speaker, it should be located on the back of the speaker measured in ohms. Make sure that your receiver matches the impedance of your speaker. You can find this in the settings of the receiver.
Need an owners manual
All you have to do is go to Pioneer's USA site and get the PDF file for the manual. You may need to Google search to find that link (just search on model no. and look for Pioneer site link) as it is a retired model. I just purchased one from BB but it was complete.
PIONEER VSX-1018AH NO SOUND OUTPUT
If this is a new hookup be sure this amp doesn't have pre-out/main-in jacks that may need to be bypassed. Otherwise, maybe look to see if any tape deck buttons are pushed. Good luck.
Pioneer VSX-1018AH-K 7
Check if Zone 2 is 'On' if it is set it to 'Off' using the front panel button. Hitting the 'Recieiver' and 'Setup' buttons is the correct way to set the system up.
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
