1000 Watt digital power inverter/ charger also battery voltage displayed on inverter is higher than what I measured with the multimeter at the battery.14.7 volts verses 13 volts as measured
SOURCE: need small microwave for inverter on houseboat
Look at the rating sticker on the oven and use the AC power rating as your guide. The cooking power of the oven is not important, but the power it needs from the AC supply is. Voltage times current is the supply power needed (watts), and you want an oven that will draw less than the inverter's continuous rating, less any power being used by other appliances.
For instance, a microwave rated for 120 volts AC at 10 amps needs 1200 watts. Your inverter would be OK with this as long as other devices aren't using more than another 1000 watts. You can't use the inverter's peak rating. That's only for brief bursts, like when the microwave first kicks on and draws some extra current.
Any mid-power (600 watts or so) oven should be OK.
SOURCE: Run a CPAP on a power inverter
I would not do this, you really need a pure sine wave inverter to guarantee the safety of your CPAP machine. At the price they are selling this device it could not be pure sine wave. 150W pure sine wave would be $70-$100.
SOURCE: i have 800va microtek inverter non sine wave.i want to know what is the output voltage available
The voltage should be the same for both. Maybe one or the other isn't calibrated correctly. Have a friend with another multimeter check the output, and then take the voltage that is the same from his and yours.
SOURCE: Grundfos Pump On Xantrex Modified Sine Inverter?
SOME MOTORS HAVE TROUBLE, starting on Modified sine wave power. Grundfos is a high quality unit, you could try an other motor driven load to see how it is handled by your power supply.
SOURCE: can I plug a camera, shaver, or cordless tool battery charger into this Modified sine wave
It depends on the charger. Many, especially newer, battery charger do not like modified sine waves at all. It's funny, I can run my desktop computer all day long on one, but I "smoked" a laptop power supply trying it. If the charger says don't do it, then don't do it.
The problem is not with the battery, it's with the way the charger itself is designed.
