The wireless keyboard keys like j , k and l responds to 1, 2 and 3 which it should do when fn key is pressed.the above function is working properly in other laptop but not in msi .how do i fix it?
SOURCE: acer 3000 when I am
usually this means you are having a critical keyboard error. if its still under warentee then take it back but if not then just look for another keyboard for that model on ebay.
should be able to get one for no more than £20.00
matt
SOURCE: fn key on dell inspiron 1501 keyboard not working
Sounds like your number lock is on. Find the key with blue lettering that says 'Num Lk' (or something very similar). Press Fn and that key, and your number lock will be turned off and your keys will go back to normal.
Hope this helps.
SOURCE: FN + F2 did not function in my ASUS laptop.
Restart> press F2 on boot = BIOS
Wireless device > ENABLE
SOURCE: On a Gateway laptop, the keyboard always
Press Fn Plus the Numlock key that should turn the numlock off
SOURCE: my laptop keyboard is stuck using the Fn keys
is your number lock on? if it is turn it off and everything should be fine...
