You can feel water going through hose but not in dishwasher
SOURCE: Hotpoint Ultima dishwasher DF32
you are probably plumbed in under the sink for the drain hose. a common problem is water coming back down the drain hose when you empty the sink. if so take the drain hose up as far as possible in a swan neck. other possibility is a leaking fill valve
SOURCE: water will not fill into dishwasher
hi, it could be the inlet valve. This is usually what the hose fits to on the outside of the machine, and on the inside is the valve. MAKE SURE THE POWER IS OFF BEFORE you take the wires off the valve, then check for a reading on a ohms meter.ACROSS THE TWO TAGS, If no reading on the meter, the valve is gone. Regards, Tom.
SOURCE: dishwater fills with water, hot...but doesnt wash?
when in the wash phase, listen for a low hum near the wash pump. if you hear this it indicates the wash pump capacitor is faulty or something jammed in the pump.after that you will have to access the wash pump and check if there is any supply to it
SOURCE: Dishwasher will not go thru wash cycles
Hi
You have a problem which will need some knowledge of how the machine works and some test meter.There may be a problem with the motor.It may not beworking,jammed or dead -burnt out.The motor does the work after the water-cold,hot or medium-has entered.
The timer-you say works- will connect power to the motor to do its job,power to solonoid for the valves to open at the right time to let water in and out-pushed out by the motor.Remove the water with a cup and rags from the machine and then see if the motor turns by hand.This may mean you have to get under the machine.ALL WAYS REMOVE THE POWER CORD AT THE WALL POWER OUTLET--Jay
SOURCE: whirlpool dishwasher adp550
f4 is a drain error, machine is still sesing water has not pumped out after 4 minutes of draining
1st check and see if water is still in bottom of machine if so check for blockeges under sink where drain hose cnnects to drain pipe.
if water has drained out you may have an water sensor fault or worst case an electronic control board fault
to reset machine hold the start button in for at least 3 seconds and it should do a drain and stop
Hi
When the Dishwasher won't fill you'll need to
check for the water inlet hose, the water inlet valve and the float switch
assembly. When the water fills your dishwasher, a float rises along with it. As
the float reaches a certain threshold level, it shuts off the flow of water,
thereby preventing a leak. Sometimes the float can get stuck in the wrong
position in your dishwasher, and it can prevent your dishwasher from filling.
Sometimes it can happen due to float valve and on other occasions due to float
switch. Inspect the water hose coming to the dishwasher for any blockages. If the
hose is not clogged then check the water inlet valve for any clogs, if the
water will not even fill for few seconds then certainly the water inlet valve
is bad and should be replaced. You can also use a multimeter to check
continuity on inlet valve. If you don't get any value on the multimeter then
you'll need to replace the water inlet valve assembly. However, if the valve is
fine then the float switch assembly should be replaced. Hope this helps...
Please post back if you need more information.
Daniel
