I forget to open the case first and look, omg oops BP made 2 PC's with that name, one is laptop and other a desktop, the laptop shows Backard bell, BV (BV mean made in dutch factory)
Information on replacing the CMOS battery on Intel® Desktop Boards. ... This type of CMOS battery is connected to an onboard header on the board by a ... We recommend you search for online retailers by searching for CR2032 with wire.
I'd recycle this pig. for sure.
a very rare PC, not sold in uSA.
here are the 2 PCs sold outside USA.
named both Pegasus.
hard to find but here they both are.
if your PC is laptop, say that first.
desktop remove left panel (after line AC cord pulled first)
see the coin cell , replace it.
laptop (no books to find so...)
Line (AC) cord pulled
Bighuge battery remove now.
then.
1: remove all bottom hatches to find a coin.
2: with hatches open remove all cards seen in sockets there, RAM/WIFI/etc to see if coin is seen now,?
3: next is try to pull the keyboard as a unit. with bottom of laptop screws off for KBD pull. if missing said screws that means the keyboard, is part of top or has very custom top of PC kbd, latches, only a service manual disclosed how.
4: still no COIN cell seen?
so we remove top from bottom sections.
using screws or snaps, as the situation applies.
after all the service manual covers this but not for TOY grade PCs like this. ever.
5: and the really hard PCs the mobo needs to be removed next to see it's bottom side and fully hidden COIN cell is seen.
there you go the 5 steps all techs know.
and how not to wreck ribbon connectors of 3 types (skill sets there)
if dutch PC why not ask them, contact the factory there speak dutch and ask them.
nah.
next time avoid any PB products,
Acer owned then name from 2000 to 2008,
as the wiki tells.
its now BPX,.. and not PB now.
find the battery in the PC
or find the battery in a store.
no country stated, so only PC answered.,
SOURCE: BIOS problem!!
Why do you want to overclock it? Have you changed the cooling system? Overclocking might fry your processor if the cooling cannot keep up with the heat. Does your motherboard support overclocking? The option might be locked. There might be a jumper on the board that you have to mingle in order to enable that setting.
SOURCE: opening a packard bell imedia case
there are probably a couple screws on the back to undo then it slides of or
look under front f case on slightly older ones pre 2000 cases
they have screws under front face plate there is a little hole there put your habd in there and yank it off
you wont damage it there usually stiff
SOURCE: my power supply for packard bell blew up due to much power,so i
The style of power supply is different from a universal power supply. A universal power supply won't fit in the slot properly.
This website has it for fairly cheap:
http://www.partstore.com/GetModel.aspx?MfgName=Sumitomo+Group&BrandName=Packard+Bell&ModelNumber=845061&Page=1&SortBy=idealitemnumber&SortDirection=desc
SOURCE: i forgot my bios password of my laptop packard bel...
This information is intended for experienced users. It is not intended for basic users, hackers, or computer thieves. Please do not try any of following procedures if you are not familiar with computer hardware. I'll not be responsible for the use or misuse of this information, including personal injury, loss of data or hardware damage. So use it at your own risk.
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
SOURCE: Where is the jumper to
During the boot up process you will see on the screen press delete to enter set up Press delete during the boot up process to enter BIOS scroll down to set user password you can change or remove your password from there hope this helps
