SOURCE: Wireless thermo clock not reading outside temp
I've had a similar problem with another model, an Oregon Scientific Model IWA-80055 Wireless Thermo Clock, in which when I replaced the batteries in the remote sensor, the clock would not read the temperature from the remote sensor.
I found it fairly consistent to solve this by taking a battery out of place in the clock and putting it back in. Unfortunately this also messed up the clock's time and date. This is also in the instructions catalogue for the device, check and see if yours gives a similar solution.
SOURCE: The outside air temperature sensor for the 2003 Camry
the sensor is located in front of radiator if you open hood and look down behind front bumper you should see it, or look from under the frt bumper, it easy to change, also get part from dealer it not $$,hope this helps.
Testimonial: "Thanks-- I found it."
SOURCE: silicon scientific atomic projection clock did no ...
I have one of these, and look for the manual on the 'Net every time DST changes, and eventually figure it out. Here's how: (1) Hold down the ALM/SET button until you get past the alarm setting and you see 24H or 12H. (2) Step through the settings by pushing the ALM/SET button, changing each as desired by pressing the +/CYCLE button. Eventually you'll wind up with the time zone indication flashing (it's really tiny, and appears just below the time indication). Press the +/CYCLE until you get to the desired time zone. (3) After the screen quits flashing, press the -/DST button to get the desired setting. I hope this helps, and that I can find this post again next time change!
