WE HAD RECENTLY BOUGHT A SECOND HAND SUBARU EXIGA FROM JAPAN WHICH HAD CLARION GCX609W STEREO SYSTEM, THE INDICATIONS AND THE DISPLAY TEXT IS IN JAPANESE IT BECOMES DIFFICULT TO OPERATE IT. IS THERE ANY WAY WE CAN CHANGE ITS LANGUAGE TO ENGLISH?
I have same model Clarion GSX609W. And from this article you can see that its not possible to change language. You cant even change the time. Here is the link to the article i found
https://www.drive2.com/l/9932572/
Most electronics come with several choices, the difficult is as you say it's in japanese. if there is a menu window then slowly go through seeking the word english you might be lucky and it shows you can but try , click and see result. if gorgeous female steps out may i have first refusal. lol. good luck
ps you could learn japanese lol
SOURCE: LANGUAGE SETTING JAPANESE TO ENGLISH
Hello analyn
There may be a simple fix to this problem.
Find a friend that has a cybershot of the same model as your own. In their camera, open the menu and navigate to the language setting. While you do this count how many times you press the button. Example:
Menu
-camera settings 1
-program 2
-personal settings 3 press ok
personal settings
-storage type 1
-date and time 2
-language 3 press ok
language
-spanish 1
-english 2 press ok
-japanese
Although the language is different, the number of spaces should be the same, so even though you can't read it to change the language, you should be able to count it out. Or if you are lucky you may have a Japanese friend who can read it.
Hope this helps
-Chris
SOURCE: Japanese to English Version
I am not sure if this will help or not but it is worth a try. Here is how to change the language. Hopefully there will be a option to choose English.
How to change the language:
Note: Some games that feature multiple languages may display in the language you have selected in the system settings.
English.
SOURCE: changing language from japanese to english
i have a panasonic CN-HDS955 car stereo and it is in japaneses and i want to change it to english
SOURCE: How to switch language on japanese bought sony dsc-wx1 cybershot?
I bought a camera in Japan (Sony Cybershot DSC-WX1) and now it seems that i can't change the language from japanese to english. If i select (can't read it but with the help of the english digital guide i think i have the right menu)change language, there seems to be only one language available. -japanese- How do I solve this?
SOURCE: Setting time and CD Player Error 3 on Addzest Car Radio.
Error code 3 means the laser can't read the CD. Use a lens cleaner until it works. Otherwise, it's junk.
