Coffee Makers & Espresso Machines Logo
l
larry ludwig Posted on Oct 30, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why is my bunn coffee leaking water from the bottom when i add water
Marks concession repair
Level 2:
Habit-Forming:
New Friend:
  • Expert 76 Answers
  • Posted on Apr 27, 2019
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
76
Questions
0
Helped
40663
Points
112
Water pan exit plugged up from lime scale so water fills over the top into the unit and out the bottom.
john h
Level 3:
Top Expert:
  • Bunn Master 29,492 Answers
  • Posted on Oct 30, 2018
john h
Bunn Master
Level 3:
Top Expert:
Answers
29492
Questions
0
Helped
7546830
Points
193431
Cracked container overfill spillage
Atul
Level 1:
New Friend:
  • Contributor 1 Answer
Atul
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
316
Points
5 Related Answers
Anonymous
  • Posted on Dec 11, 2008
SOURCE: my bunn coffee maker leaks
You need to replace the washer kit inside the top of the maker. Remove the 3 screws that fasten the top and lift it off. You will see the rocker leaver that allows the water to flow into the tank. At the point where the rocker stops the water there is a series of washers that degrade from the heat over time and allows the leak. The washers are very easy to replace. The problem is finding the washer kit. I found it at: www.buyitnow64.com for $3.95 plus shipping (FedEx is only $9.98). I bought 2 (one for backup) kits.The original washers lasted almost 6 years. I had repaired this problem before with a washer from my shop but it broke down rather quickly from the direct heat from the tank. This washer kit is a Bunn washer kit that is supposed to fit all Bunn machines both residential and commercial.
Hope this helps. It took me 2 hours on line to find the washers!
Anonymous
  • 131 Answers
  • Posted on Feb 13, 2009
SOURCE: Bunn coffee maker leaks water
There are 3 seals in your unit that could cause your problem. there is a silicon seal right under the pour-in tray, and two on the top of the tank. one of those is for the thermostat, the other is for the sprayhead tube. any of these could leak, causing water to come out the bottom of the brewer. One other thing that can cause this is a scale buildup between the pour-in tray and the tank.
Anonymous
  • 189 Answers
  • Posted on May 19, 2010
SOURCE: I have a bunn coffee maker the NHBX is the # it is
Please give Customer Service a call with the model and date code. If the machine is 3 years old or less, it will be replaced with a new machine. If it is older than 3 years, it can be exchanged for a reduced price.
Anonymous
  • 189 Answers
SOURCE: Bunn coffee maker leaking from underneath the bottom
Please get the model and the date code from the bottom of the machine and contact customer serivce. Depending on the date code, there might be a seal kit available or the machine can be replaced at no cost if 3 years old or less. If it is over 3 years old and the seal kit isn't available, the machine will be replaced at a reduced price.
Jafu
Jafu Bumbalini
  • 9 Answers
  • Posted on Jun 25, 2012
SOURCE: Bunn Coffee Maker Leaks out the bottom
I have an older BUNN B10 pour-o-matic that I thought was leaking from the bottom. Upon close inspection, I found that it was leaking from the worn out washers located on the top of the tank, allowing water to run down the sides of the stainless steel tank. There's a great fix offered on Fixya.com that suggests going to a hardware store and buying a Gardner Bender GHG-1575 rubber grommet with a 3/4" hole and install it into the large hole in the basin. Then place a metal washer on top of the grommet and snug it up with the threaded fitting. Many folks say it's a great fix. I went a different route. I called BUNN customer service and spoke to a very nice woman who understood my needs and sent out a free repair kit that contained a new fitting, washer, and seal. I received it in a few days and it's working great. Beats going out and buying parts for a work around repair. BTW, the repair kit is called "Universal Retail Seal Replacement Kit #37091.0000"
Why does my bunn coffee maker leak from the bottom when i add water
It could be so much lime build up that the water going in is too much for the water to come out so it will leak out the top from the thermostat hole plug and or the water pan is flowing over the top cus no place else to go?
Bunnamatic is leaking out of bottom of unit
Contact Bunn online. They will send you a repair kit with instructions.
1helpful
2answers
My bunn coffee maker is leaking water out of the
Please get the model and code date located on the bottom of the brewer. The machine has a 3 year warranty and if it is 3 years old or less, it will be replaced at no cost. If it is older than 3 years old, it will be replaced at a discounted price. Once you have this information please call customer service.
2answers
Bunn coffee maker leaks all over the counter. What
there's probably a 'silicon rubber' hose that feeds hot water to the 'grounds basket'- it may be loose, or damaged. is it leaking water, or coffee?? we have a bunn 8-cup, which has a pre-heated water tank that brews a pot in about 3 min. energy waster, but when you need coffee, you need coffee!!! is your filter holder properly centered? is the carafe lid hole clean and un-obstructed?
if it's leaking water, and not too costly to replace- you may consider replacing it with a new one!
good luck!
I have a GRXB bunn 900 watt 10 cup coffee maker that leaks from the bottom when you add water. can you help me find the problem
If sounds like a bad seal/gasket. Please call customer service with the model and date code. If your machine is 3 years old or less, it will be replaced at no cost. If it is over 3 years, depending on the date code, there is a seal kit available to repair the leak. Or we can replace it at a reduced price.
2helpful
2answers
Leaking a half cup of water from the bottom while brewing
Call bunn for replacement gasket free of charge per recall.
9helpful
4helpful
4helpful
2answers
Bunn Coffee maker
your problem is caused by the pour-in tray leaking where it mounts to the tank. There should be 2 screws under the pour-in lid, and a third toward the rear of the brewer. if you take them out & lift up carefully, you can see the pour-in tray. in the bottom of the tray, there is a bolt that mounts the tray to the tank. If you remove that, you can lift the pour-in tray out. Be careful, as these trays get brittle over time, and are prone to cracking.
Top Bunn Coffee Makers & Espresso Machines Experts
vince
john h
ADMIN Andrew
ADMIN Andrew
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
