Video Game Consoles & Games Logo
Tom Goetzinger Posted on Oct 29, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you raise flaps on Logitech extreme 3D pro when running Microsoft flight simulator x
Giselle
Level 3:
Genius:
  • Microsoft Master 1,015 Answers
  • Posted on Oct 31, 2018
Giselle
Microsoft Master
Level 3:
Genius:
Answers
1015
Questions
6
Helped
286185
Points
2407
At FIFACOINSZONE you can buy cheap and safe FIFA Coins, best FIFA Coins here.
5 Related Answers
A
Anonymous
  • Posted on Dec 27, 2007
SOURCE: joy stick
this worked for me, i have a ibookg4 and all all my dad had to do (complete nerd) had to do was REBOOT THE COMPUTER WITH THE JOYSTICK PLUGGED IN and the joystick worked after that.  Posted by his dumb as a post sun...
Anonymous
  • 64 Answers
  • Posted on Feb 02, 2009
SOURCE: installed joystick extreme 3d pro wiil not work
Sometimes on those games, if you used a mouse originally, they do not auto-detect that ur using a joystick now - go into the options tell the game ur using a joystick and also there you may be able to set custom control features (what button does what).
Please let us know how it went.
**.The best way to acknowledge contribution is to rate it's relevance.**
Anonymous
  • 86 Answers
  • Posted on May 27, 2009
SOURCE: wingman extreme will not work with my vista.
Changing the game to work in compatibility mode for windows xp may solve your problem. right click the game >properties >compatibility and set to windows xp. Good luck!
Anonymous
  • 20 Answers
  • Posted on Jul 03, 2009
SOURCE: Logitech Extreme 3D pro restarts computer
goto logitech.com
enter your joystick model in
"gaming"
"gaming" then in
"product name"
enter your model joystick,
get updates and software.
reinstall your software for your joystick
Open SKy
Carlos L. Burgos
  • 620 Answers
  • Posted on Jan 21, 2010
SOURCE: Logitech Extreme 3d Pro Calibration problems.
Hello There,
Also dont' I meant NO, Do NOT install the software that came with the joystick, it lure a lot problems on calibating and others.
use the game control panel on windows instead.
good Luck
Why won't Microsoft Combat Flight Simulator for Windows 98 recognize my logitech joystick?
click on the joystick and then click on the properties tab
check and adjust compatibility
tick the box and move down the list to win 7 and click that ---apply and ok
it sound slike a compatibility fault or a missing driver for the joystick
No where to plug in microsoft sidewinder3d pro will his work for microsoft flight simulator
The 3D pro has a game port connection. The older Sound cards came with game port connectors. Yes it would work for MSFS if you had that connection on your computer. Best bet is to go pick up an under $20 Saitek at your local Walmart/BestBuy/OfficeDepot. They are USB and work with MSFS just fine.
MCFS Joystick Problem
Make sure, that your Joystick is compatible with the version you are having problems with. If not, make sure that it's enabled in the configuration of MCFS. If none of those work, you will most likely have to purchase a more compatible Joystick.
Matt P,
Computer/Gaming Relations Team.
Wingman extreme will not work with my vista.
Installed joystick extreme 3d pro wiil not work
When I bank right or left with joystick the screen Freezes
To check the joystick isn't the problem, go into control panel game controls, then check that the joystick appears and you can move the cross-hair around on screen, most modern joysticks are
auto-calibrating, but you could try running the calibration.
To check the game isn't a problem, unplug the joystick, then use the arrow keys to fly the plane, if it doesn't crash when you bank then it isn't the game.
I assume the game is Combat Flight Simulator 3, as very old games that were written for Windows 95,98,ME series often won't run on Windows NT,2000,XP,Vista as they are completely different versions of Windows. If this is actually Flight Simulator 3, you may need to consider buying a later version of Flight Simulator (FSX is the latest version, but may not run on your laptop).
Other things to try are updating the graphics card driver.
Norton shouldn't need deactivating, although it could cause problems if you're playing online.
Also remember that laptop graphics cards are never as powerful as desktop graphics, and games very rarely specifically support laptop graphics.
Hope this helps.
1helpful
2answers
Hello There,
good Luck
Flight simulator
Have you tried to set the control sensitivities on FS ? Try turning them down and try again. JLS
1helpful
Joy stick
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
