Question about Sanyo Computers & Internet
Noise in system
The Sanyo split makes a whirring or humming noise when on. What is wrong
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 40 Answers
Normally refers to bad ground,
Posted on Nov 07, 2018
SOURCE:
motor1258
  • 6674 Answers
SOURCE: humming noise in front end/engine fo 2001 Cadillac STS
Keep an eye on your temperature gauge until we figure this out, just in case & see if it climbs much/any at highway speeds.
Posted on Feb 27, 2009
  • 1129 Answers
SOURCE: loud whirring noise at start-up
The first thing to check would be to make sure the power steering reservoir is not running near empty, locate the filler cap for the power steering pump it should be marked and then add the appropriate amount making sure you don't over fill, that may make the sound go away if not we must move on to the next possibility, by the way if the noise gets louder when you turn the steering wheel it is most likely the power steering pump or fluid level is low.
Posted on Jul 14, 2009
  • 114 Answers
SOURCE: My front end makes a loud humming noise.
Alignment will not create a sound by it's self. The most common cause of humming (especially if you have an agressive tread design)is a wear pattern in the tires...check for that or rotate the tires around & see if the noise changes. If it does then you know it's in the tires. & Not always, but most of the time a bearing noise will increase or decrease in intensity if you load up one side at a time by doing 35-50 mph & turning slightly to each side.
Posted on Sep 30, 2009
  • 497 Answers
SOURCE: my truck makes a high-pitched whirring noise when
the high pitch noise leads me to believe a problem with the hyudraulic clutch. Have you checked the level? also with manuals you dont have tranny fluid, you have gear oil; which is very unlikely that needs changing
Posted on Nov 06, 2009
SOURCE: whirring noise from engine area - increases with acceleration
Mine did the same. It was a bad idler pulley
Posted on Nov 09, 2009
Ive got power, hot and cold to my existing pump and shower, but the pump doesn't start, just makes a whirring noise.
Above Ground Pool Pump Won't Start or is Humming & How ...
? 6:16
https://www.youtube.com/watch?v=RH78q36liks
Apr 15, 2014 - Uploaded by Above Ground Pros
Above Ground Pool Pump Won't Start or is Humming & How to Fix It ... Pool Motor - Humming-Loud Noise ...
How to fix your pool pump from humming - YouTube
? 2:43
https://www.youtube.com/watch?v=3v2v6aDDq9A
Mar 25, 2013 - Uploaded by James Hayward
Do you have a pool pump not priming (pumping water) andmaking a humming noise ... not only give a ...
pool pump makes humming noise and does not pump - Trouble F
Dec 08, 2015 | Home
Laptop making noise
You need to get pressurized air and blow the vents to remove dust particles causing over heat. Or if possible remove keyboard to expose cooling fan and chip and use pressurized air to blow off dust
Aug 06, 2013 | Toshiba Computers & Internet
Noise coming from the rear end of my 2004 honda pilot it really only occurs during cold weather and after it warms up you hear it slightly
When does the noise occur, while driving only, or driving and idle, in gear, or in neutral and park? If it occurs all the time (while driving and at a stand still in cold weather) it could be the fuel pump. If it occurs only while driving, it may be a wheel bearing. Describe the noise (humming, grinding, whirring, etc), and what is the mileage on the Pilot? Answer my questions so I can fine tune my answer. Thanks!
Mar 18, 2010 | 2008 Honda Pilot
The noise is a hum or buzz. We've narrowed it
By chance have you tried making sure the laptop is not too close to the speakers? Sometime you will get feedback when the source is to close to high powered speakers. Also, check your jack cord and make sure no splits/cuts are visiable and the plugs are fully inserted.
Good Luck and keep making great music. Aloha.
C2Solutions
Sep 02, 2009 | Dell Inspiron 6000 Notebook
A/c making noise and then switches off itself
your piping system is cloging. call tech. to check it
Jun 14, 2009 | Heating & Cooling
Aircon compressor makes noise
Is this noise definately from the compressor? have you looked round the system for a loose componant like the fan? is this system a heat pump sorry I have not checked online but if it is what is the sound like in heat mode, if just coling unit please ignor last.
Jun 08, 2009 | Sanyo CM3172 Air Conditioner
Loud humming noise
this problem is sif coil & sound releted 5.5 crustal &releted pf try this
Jun 21, 2008 | Sanyo DS19330 19" TV
GE SidexSide PSS26SGPASS Makes Humming Noise
GE refrigs have a variable speed evaporator fan motor that is controlled by a computer board on the back of the refrig. now the noise you are hearing is most likely the fan motor ramping up and down in speed (some of my customers say it sounds like a ghost). if its a continuous ramping up and down then the speed cotroller on the board is bad and must be replaced. if its just an occasional sound then thats normal and nothing to worry over.
Btw the reason the noise stops when the door opens is because the fan shuts off when you open the door.
Dec 19, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Computers & Internet Logo
Top Sanyo Computers & Internet Experts
Marvin
Marvin
john h
ray gallant
ray gallant
Are you a Sanyo Computer and Internet Expert? Answer questions, earn points and help others
