Question about Jacuzzi Home
I have a aquatic av with my Jacuzzi hot tub and the fuse keeps blowing. There might be a BONDING issue. The model# aq-ps-5r and the radio model # aq-ip-3b-x. Any help would be appreciated
Check heater element and recirculation pump
SOURCE:
SOURCE: need a users manual
Kathy,
I think what you're looking at are the part numbers for the heater and control systems used in some Jacuzzi hot tubs rather than the Jacuzzi model number. I ran into the same issue and discovered through some cross-referencing on the web (jacuzzi parts suppliers) that this is the part number control unit made by Balboa. Odds are they were used in multiple Jacuzzi models.
My suggestion: Look here http://clearcreekspas.com/model_id.html to identify the control panel for your Jacuzzi and then follow the link to the correct manual. Some cover multiple models so you will need to know the electrical requirements of yours (120 V or 240 V?) and then check the layout of each tub shell to determine which model is yours.
I figured out mine is a Jacuzzi Essence Model 350 this way.
Posted on Dec 07, 2008
lebones337
  • 152 Answers
SOURCE: Radio fuse keeps blowing out
maybe this link will help
http://www.autozone.com/addVehicleId,2638501/initialAction,repairGuide/shopping/repairGuide.htm?pageId=0900c152801ee281
Posted on Jan 02, 2009
  • 10865 Answers
SOURCE: Leaking pipe in a jacuzzi hot tub
The only product I know of which will do what you ask is an item called Plast-Aid Acrylic and PVC repair kit. Google it and you will find the website. It is about $20. and it works like a charm. good luck
Posted on Jan 21, 2009
  • 412 Answers
SOURCE: radio fuse keeps blowing
make sure nothing in cig lighter socket..coins,etc..if nothing present,unplug cig lighter socket and replace fuse..if fuse doesn't blow,it's the socket causing fault..if it does,unplug radio,plug cig lighter back in and replace fuse..if fuse doesn't blow,radio is cause of fault..if it does,then ther is short in wiring
Posted on May 19, 2009
darjr
  • 379 Answers
SOURCE: starter fuse under the hood keeps blowing....the factory deck was replaced by a new deck...every since then the ignition fuse keeps blowing..
The fuse is always blown due to overload fuse, check the rating of fuse is it the same as the original fuse?.
Posted on Jun 01, 2009
I need to find a service man in the Seattle area to get my tub working. It has power but won't come on.
then look in a phone book for a plumber . I am sure there are more than 1
Feb 11, 2016 | Home
My hot tub will not heat up and the one pump is running. I can not turn the lights on or adjust the controls
check the fuses if no heat sounds like the pump that isnt running is the recirculation pump (which heater is connected to) if fuses keep blowing try disconnecting the heater element maybe shorted
Mar 04, 2015 | Jacuzzi Pool & Spa
No power to tub
open power control box check to see if voltage coming in. also check fuses. check voltage before transformer and after see if voltage is correct if you put in new fuses disconnect the heater element and the recirculation pump plug one in at a time to see if it blows fuses
Mar 22, 2014 | Sundance & Jacuzzi Hot Tubs Complete...
Newly installed jacuzzi only has hot water for about 30 seconds, then water is tepid only.
This issue will have nothing to do with the jacuzzi tub. You will find the problem exists in the way your home was plumbed by the plumber.
Somewhere there is a clog in the water line going to the hot water faucet.
Find that and you will solve your problem.
Rod
US Parts Center
Mar 06, 2014 | Jacuzzi Home
Circuit braker keep popping
Sounds like the heating element has gone out again. Once you reset the circuit breaker and the tub turns on it will start to circulate the water. This usually runs like this for about 2 mins and then the tub will recognize it is cold and send power to the heater. If the element is back at that point it will blow the circuit breaker.
If this circuit breaker pops as soon as you turn it on then you most likely have a bad circuit board.
Rod
www.uspartscenter.com
Jan 30, 2013 | Jacuzzi Home
Need to figure out how to clean out the black stuff that comes out when we turn on the air jets
You need to get some jacuzzi cleaner solution or hot tub jet cleaner solution fill the tub with the solution and follow directions to clean them out needs to be done every couple months IF THIS HELPED PLEASE VOTE FOR ME
Aug 26, 2011 | Whirlpool Aquatic Infinity 1 66X66X25...
Grounding wire# 8 cooper
The # 8 wire is a bonding wire for the hot tub or jacuzzi. It is to interconnect all the metal parts and equipment associated with the unit, pump, pipes, handrails, and also now there is a bushing that goes in the piping run to bond the water itself .
This wire will be incdentally connected to the electrical ground when it is bonded to the motor body.
Jun 10, 2010 | Jacuzzi RapidHeat Inline Heater S750
The installation guide says that the heater unit needs to be bonded. there is the copper wire and the place to hook it up to the heater. but what dose bonding mean? Grounded?
The term "bonded" refers to properly grounding the heater. A 10-gage copper wire is needed between the heater and a metal water pope or grounding rod.
Sep 24, 2009 | Jacuzzi RapidHeat In-Line Heater U395000 [...
Need a users manual
Kathy,
Nov 11, 2008 | Balboa Instruments Garden
Home Logo
71 people viewed this question
Top Jacuzzi Home Experts
US Parts Center
US Parts Center
Mike
john h
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
